Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 08-04-2002, 09:23 PM   #1
83Excella
83Excella's Avatar
Profile:
Durafix aluminum repair
Has anyone used this stuff? does it work?
http://durafix.com/
John
83Excella is offline   Reply With Quote
Old 03-22-2003, 08:03 PM   #2
Gene Wissink
Profile:
I just finished working on the wheel well trim, I had the bottoms where they go under the body come loose, the PO tried to fix them by using extra long pop rivets to hold them in place but they pulled out. I used the alumimum repair rod to fasten some tabs on the wheelwell trim and then riveted them to the plate that is fastened to the frame.
Gene Wissink is offline   Reply With Quote
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 5 09-24-2006 12:17 PM
Interior Aluminum Replacement swebster Upholstery, Blinds, Walls & Interior Finishes 34 02-24-2005 10:14 PM
aluminum composite countertop repair? Janet Cabinets, Counter Tops & Furnishings 1 09-30-2003 10:38 AM
Sheet Aluminum repair lee_jachter Ribs, Skins & Rivets 8 11-23-2002 09:48 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 06:49 PM
