Old 06-19-2012, 10:06 AM   #1
2002 25' Safari
High Ridge , Missouri
Dump valves 'nite light'
I own a 2002 25 safari and after changing a bad bulb in the nite lite just behind the dump valves I still cannot get it to work.
Any suggestions?
Cramalot is offline   Reply With Quote
Old 06-19-2012, 10:52 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
First off, welcome to the Forums. We're glad to have you with us.
As to your question, I also have a 2005 Safari (25 FB). The switch on those sewer night lights are notorious for going bad. I am now on my third light unit, and it has recently gone out, again. Since that light is just about useless anyway, I don't think that I will bother replacing it. I use a florescent work light when I need to attend to sewer matters after dark.
Brian
SuEllyn & Brian McCabe
Old 06-19-2012, 11:11 AM   #3
reddogfox's Avatar
2008 20' Safari SE
Thumb Area , Michigan
I had the dump valve light on my trailer fail after 4 ½ years of service. The problem was not caused by the bulb but failure of the Judco pushbutton switch. I bought a replacement from DigiKey Corporation link below.
40-2386-00 Judco Manufacturing Inc | 505PB-ND | DigiKey
Richard from MI
20' 2008 Safari SE, Dill TPMS Silver Dog House
2007 GMC 1/2 ton Sierra ARE Cap
AIR # 10494
reddogfox is offline   Reply With Quote
Old 06-19-2012, 11:51 AM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, in eight years, I have only used my sewer light once. I replaced the switch with a heavy duty water proof toggle switch.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-19-2012, 02:14 PM   #5
btowntincan's Avatar
Mercer Island , Washington
I didn't even know there was a light.
Where is the switch, Robert?
btowntincan is offline   Reply With Quote
Old 06-19-2012, 02:45 PM   #6
Salem , Oregon
Images: 18
Hi, I don't have a good picture of it, but it is located right above the sewer connection. The switch is just above the light.
2005 Safari 25-B
Old 06-19-2012, 02:58 PM   #7
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
My light works fine but I wish they would have put one above the tube that holds the sewer slinky. That flat lid covering the tube is almost impossible for me to get into the locking position. I know there must be a simple way but I just keep fumbleing with it. The step light, jack light and the light above the sewer connection are pretty useless.
TAC
Hope is not a plan.
danlehosky is offline   Reply With Quote
Old 06-19-2012, 04:02 PM   #8
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I would forget about the sewer light; it is easy to leave on or bump on unknowingly and will drain your battery. Same thing applies to the lights in the storage compartments. Shifting cargo can turn on the storage compartment lights. Better the lights were not there.
A simple LED headlamp works just fine for dumping and for replacing the cover on the hose storage..
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 11-18-2015, 12:23 PM   #9
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Here is where you can purchase a new switch and the rubber cover for it. I purchase several of each since they are cheap enough.
40-2386-00 Judco Manufacturing Inc. | 505PB-ND | DigiKey
Kelvin
Old 11-19-2015, 06:30 PM   #10
Retired
tvketchum's Avatar
2008 30' Classic
Livingston , Texas
I added a light over the slinky tubes. Power was easy to reach, as the side storage compartment is just above it. Detached the light, drilled a hole for the wire to pass to that area in the dark curved trim. Works great, and no lost slinkies.
Tom
TVKetchum
Tom
AIR 71620
WBCCI 5809 Reg 5 Unit 041
2008 Classic 30'
2013 F150 Ecoboost
tvketchum is offline   Reply With Quote
Old 11-20-2015, 12:50 AM   #11
Salem , Oregon
Images: 18
Hi, my most recent and hopefully last sewer light re-do.
ID:	252529   Click image for larger version
2005 Safari 25-B
