Old 04-07-2018, 07:23 PM   #1
Bassett , Virginia
Dummy me used the axle as a jack point. Should I worry.
I just changed my 27fb International tires from 15 inch wheels to 16. I used a bottle jack with a nice cradle top and used the axle right behind the tire as a jack point for all four tires. It just looked like the best place but now I read that I could have damaged my axles. The jack top was shaped like a jack stand and there is no obvious external bends etc. to the axle.
Should I worry? I know better now but.........
Newbie2018 is offline   Reply With Quote
Old 04-07-2018, 07:42 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi from Colorado: Welcome to Air Forums. You may get several different answers to your question. Here is mine:
I don't believe you hurt your axles based on your description of where the jack was placed. Jacking on the swing arm where the spindle is welded is a stout piece of the axle. I think your bottle jack put the same load on the axle as if you were to pull one tire of the trailer onto a 4x4.
Where you don't want to jack up the trailer is on the axle "beam" between the frame rails. This section of axle has a "arc" to it and "bending" the arch is how the trailer wheels are aligned for tow in, caster and camber.
Some folks on dual axle trailers will pull one tire of the trailer onto a "ramp" high enough to suspend the other tire. Saves jacking up the trailer altogether.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 04-07-2018, 08:01 PM   #3
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
No worries. You are safe
Old 04-07-2018, 08:21 PM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
+1, You're good to go; no worries.
Checking on Tube before doing anything for ho videos I find very helpfull at getting pointers and tips.
Cheers
Sidekick Tony
Old 04-08-2018, 06:58 AM   #5
Bassett , Virginia
Yep, I usually check here or youtube before hand. I was drawn to the axle mostly because of being afraid to use the "jack point" on the bottom.......that really looked sketchy........I'll use it next time......after seeing others post of using a block of wood to distribute the point of the jack.
Old 04-08-2018, 10:40 AM   #6
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I lifted on the frame doubler between the wheels.
Old 04-08-2018, 11:14 AM   #7
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Between the tires on the axle mounting plate also.
Keep your eye on tire wear. If the alignment has been altered, that is how you will notice.
Richard
Old 04-08-2018, 01:45 PM   #8
Box Elder (formerly of Center Moriches, NY) , South Dakota
No, your rig is toast. You should ship it to me immediately for proper disposal....
NY24 is offline   Reply With Quote
Old 04-08-2018, 02:05 PM   #9
2016 28' International
Sioux Falls , SD
You should be fine.
Open your windows and doors to check the frame was not twisted.
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
DBinSD is offline   Reply With Quote
Old 04-08-2018, 06:46 PM   #10
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Placing the jack on the axle if you're unsure of the jacking points was actually a wise move. Missing the jacking points when trying to put the jack on the frame could mean a hole in the belly pan. As long as the load applied to the axle by the jack was where the suspension already applies a load and doesn't exceed the weight that would normally be held up by that axle on that side, you're unlikely to do much (if any) permanent damage.
A handy hint for the future, check the owner's manual and locate the correct jacking points. Then crawl underneath the trailer and apply DOT-rated reflective tape to the jacking points so that you can find them again anytime day or night in the event you need to jack the trailer again.
Marking the jacking points also helps when you replace tires, so that the service technician installing the new tires knows where to put the jacks— don't trust that THEY read the manual for your trailer! Saying, "Put the jacks on the reflective tape" can help you prevent problems when you're not the one doing the jacking.
Cats and ultraleather Airstream upholstery don't mix!
Old 04-09-2018, 05:44 AM   #11
1996 25' Excella
Tillsonburg , Ontario
It is so much simpler to use a set of blocks to drive each wheel onto and lift each tire off the ground one at a time.
JCW
JCWDCW is offline   Reply With Quote
Old 04-09-2018, 06:58 AM   #12
Unless you have a flat on a parked trailer not connected to a tow vehicle (it DOES happen, and sometimes when the tow vehicle isn't even in the vicinity). Then jacking is easier and quicker than hitching up the tow vehicle to move the trailer onto blocks.
It's not wise to dismiss any method of tire changing out-of-hand unless it's inherently dangerous to life and limb. There may come a time when you need the method you dismissed. Keep your options open.
Old 04-09-2018, 07:23 AM   #13
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
JCW
Not so much on a single axle trailer though.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 04-09-2018, 09:40 AM   #14
JCW
It's also easier to overload a tire that way. The tires on an Airstream trailer are loaded pretty close to the maximum that the tire can carry when properly inflated. When you support the whole weight of one side of the trailer on one tire and no jack, the tire up on blocks is most definitely overloaded.
Using a jack ensures that the good tire isn't overloaded while the bad tire is being changed.
Should I worry about rust on my hitch? loislane Hitches, Couplers & Balls 28 03-25-2012 12:54 PM
Should I worry? Hitch receiver rated 400# tongue but trailer 459# amm3824 Hitches, Couplers & Balls 10 04-03-2011 09:59 PM
Fridge... Should I worry? THEPILL 2006 - 2010 International 5 05-14-2010 10:38 PM
Pipe vent covers storing water... should I worry? ronstory Roof 12 10-01-2008 01:38 AM
should I worry? ostapbender Cleaning, Stripping & Polishing 3 06-19-2007 06:28 PM
