Old 05-24-2015, 09:32 AM   #1
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
Dual AC - which is which?
Hi, I just took delivery of a 2015 27' EB FB Twin with dual AC. I know zone 1 is the unit up front, but does anyone know how to determine which unit is 15,000 and which is 13,500? From the exterior cowling, they look identical (to me). Thanks in advance!
Jie
jayseejay is offline   Reply With Quote
Old 05-24-2015, 09:38 AM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Logically, the front unit would probably be the 13,500 BTU unit as the bedroom is a smaller volume to cool and the 15,000 BTU unit would be for the larger kitchen/dinette area.
In the case of our Classic with rear bedroom, the smaller unit is in the back for the bedroom.
Check the single page equipment listing for your trailer that you signed when taking delivery. The model numbers of the two air conditioners will be listed and can be checked on line to verify that there were two sizes installed.
Old 05-24-2015, 10:50 AM   #3
ramblin girl's Avatar
2016 27' Eddie Bauer
Silver City , New Mexico
Hi, We also have a 2015 27 FB EB with the dual A/C's and the larger 15,000 BTU Unit is Zone 2 which is the rear A/C in the living area.
ramblin girl is offline   Reply With Quote
Old 05-24-2015, 03:02 PM   #4
jayseejay's Avatar
Thank you both for your help! Best, Joe
Old 05-24-2015, 08:39 PM   #5
F150 4X4 ProPride
mycloud9's Avatar
2015 30' Flying Cloud
Kingwood , Texas
Zone 1 is where the Dometic Controller is located
mycloud9 is offline   Reply With Quote
Old 05-24-2015, 10:38 PM   #6
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
My Zone 1 is the rear of my 2015 Serenity 30RB
Ms. Tommie Lauer
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 05-25-2015, 08:16 PM   #7
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
You probably can't tell by which unit blows and cools the most. I had two 13,500s installed and the rear bedroom unit will blow you out of bed if you don't deflect it away from your head. I am thinking about a Home Depot plastic deflector to go behind the rear of the bedroom outlet over the head of the bed. From reading the above posts I would guess the large unit are installed in the living room.
guskmg
Old 05-25-2015, 10:07 PM   #8
1Boyscout's Avatar
2015 28' International
Edmond , Oklahoma
2acs
Ms. Tommie Lauer
My 2015 Serenity 28 RB, zone 1 is absolutely In. RB
1Boyscout is offline   Reply With Quote
Old 05-26-2015, 07:04 AM   #9
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
In my Classic, the control is in the dining room and is Zone 1.
I have been in a Flying Cloud with the controller in the bedroom as Zone 1 and the living room as Zone 2. So, I conclude that Zone 1 is where the thermostat is.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-26-2015, 03:08 PM   #10
F150 4X4 ProPride
mycloud9's Avatar
Kingwood , Texas
Zone 1 is where the Thermostat resides as deducted. 15k is den and 13.5k is bedroom. For 2015 ductless models JC will sell you round A/C vents with adjustable flow control. (Std in 2016)
Univolt internals - which fuse is which? barts Batteries, Univolts, Converters & Inverters 9 08-13-2017 09:18 AM
Dump Valves Which is back and which is grey? clicker187 Waste Systems, Tanks & Totes 7 01-16-2013 08:15 PM
Which tank is which? dejahardy13 Fresh Water Systems 8 09-24-2010 09:23 PM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 08:55 AM
