Old 01-28-2019, 06:51 AM   #1
Long Island , Long Island, NY
Dreaming of an Airstream project.
Hello,
First time poster, long time reader. Thank you for having me as part of your forum.
I am still in the dreaming phase of my trailer life but had a few ideas that I wanted feed back on.
I am approaching my 20 year military career mark and have been dreaming of the military campgrounds and becoming a snowbird to escape the winters part time.
I have been looking at getting a 30ft Airstream to rebuild to my needs. One thing that really worries me is the interior height. I am 6'4" and dont want to have watch my head or duck every second. Since my budget will involve buying an older trailer that needs work, I was thinking if I had to remove the shell anyway, why not build a 8-10inch foundation around the frame to raise the shell up for more head room.
Is that crazy? Has anyone ever done that before? Also since I am dreaming, I have found two 30ft AS that need work. Has anyone made a 40ft trailer by splicing two AS together? If I am doing shell off anyway, I could simply extend the frame and make it bigger.
Thank you for your time and humoring me.
USCGMAN is offline   Reply With Quote
Old 01-28-2019, 06:55 AM   #2
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
A good starting point, http://www.airforums.com/forums/f537...any-79254.html
truckasaurus is offline   Reply With Quote
Old 01-28-2019, 06:57 AM   #3
1977 31' Sovereign
Sunset Valley , Texas
I think you’d have an easier time splicing two together than raising the height, though I imagine where there is a will there is a way.
Look into, if you haven’t already, some of the full monte threads to see how AS’s are constructed and see if you can figure out how you’d approach the height issue.
I’m 5’ 10” and have to duck through the door.
Oh, and welcome!
Ian
Iansk is offline   Reply With Quote
Old 01-28-2019, 07:15 AM   #4
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
This is the only thread I recall on adding ceiling height.
Unknown if it was ever finished, he quit posting. Rumor was he sold it. If you plan on a lot of traveling, I'd be a little concerned with the engineering of adding that section and the 'flex' of the unit.
Hope you find a good solution. Thanks for your service.
Harold & Rebecca
http://www.airforums.com/forums/f97/...er-172124.html
57Vintage is offline   Reply With Quote
Old 01-28-2019, 08:27 AM   #5
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Whoa!!! I hope you're an engineer in the military! Lots of complexity in redesigning one of these for travel.
Here I believe is the longest Airstream made. Airstream made it for the railroad and it was 40' long. Tandom axels! I just can't imagine pulling this thing anywhere!
http://www.car-revs-daily.com/2015/0...enver-auction/
Have you looked at the newer models at all? They are wider and taller. I have a friend about your height who lives in a 30' classic. Gets along just fine.
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
***Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 01-28-2019, 09:29 AM   #6
2008 23' International
Chicago , Illinois
If you add height, remember to take into account the total height with AC units and other roof items, then keep an eye on the height of low bridges on minor roads, and other overhang issues...
Toasterlife is offline   Reply With Quote
Old 01-28-2019, 10:58 AM   #7
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
Hmmm.... an interesting proposition!
I think that just from an empty shell proposition, putting an extender module under the existing walls would be difficult to do. It seems to me that there would be an unacceptable amount of flex right in the wrong spot.
However, if you incorporated lots of bracing using bulkheads and cabinetry, it might work out. Airstream uses floating bulkheads, but this would require that they be severely attached to floor and wall.
Maybe a clerestory approach might be better? Less messing around with all of the important stuff (ext. door, plumbing, window height from floor, etc). I think that the folks converting buses to RVs have more experience in this issue. A fiberglass "tub" (turned upside down) wouldn't be that difficult to build, and could make for some nice lighting effects during the day.
SuzyHomemakr is offline   Reply With Quote
Old 01-28-2019, 11:24 AM   #8
Napa , California
While you are dreaming, consider that some of the newer Airstreams have a very nice height. My husband is 6'5" and fit into several of the newer models perfectly. He doesn't even have to duck to avoid the air conditioners and we were lucky enough to find one with extra long twin beds -and he fits on those as well.
You might want to check to see the newer ones at a dealer and decide if perhaps buying one that doesn't need to be completely redone might be a better option. Folks do trade them in or sell them because they no longer want them. You can get a really good deal if you know what you are looking for, and then do a bit of remodeling and be on the road that much faster.
Atwebs is offline   Reply With Quote
Old 01-28-2019, 01:17 PM   #9
The Silver TARDIS
Kevinshortnh's Avatar
2018 30' Classic
Gray Court , South Carolina
I am 6'3" and have no trouble in our 2018 Classic 30RB Twin. There is nothing on the ceiling to bump my head on. On the other hand, even my 5'5" wife can bump her head into the ceiling locker/cabinets.
Kevin Short
2018 Classic 30RB Twin -- "The Silver TARDIS"
2014 RAM 2500 Cummins Diesel
BlueOx SwayPro 1506
Kevinshortnh is offline   Reply With Quote
Old 01-28-2019, 02:12 PM   #10
2018 23' International
Diamond Bar , California
Pull it with a diesel...
Whatever you decide for a trailer, find a diesel tow vehicle that sounds like an Alco 251 or a Fairbanks-Morse OP. You’ll feel like you are bilge rat back on a WMEC.
David R. Busse
DRBusse@roadrunner.com
2018 Airstream International 23CB
2018 GMC Sierra 1500 4x4
DRBusse is offline   Reply With Quote
Old 01-29-2019, 08:43 AM   #11
If I close my eyes, I can still hear the Cummins VT903 light off on the 41UTB. A great sound.
Old 02-09-2019, 03:48 PM   #12
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Frame is the problem. Weak [intentionaly], flexable and only 4"s deep on the older ones. To get an extra 6"s height seems you'd have to add 6 to the hull. Skins, body bows, door frame. But, what would happen if you built a 8" frame, set / attach the hull / body bows to the top. Then set the floor inside the frame rails near bottom and increase belly pan wrap up under hull skins? theres another 4 to 6 inches. AND a lotta work. Take a look at Avion, prob a better canadate. Rigid 3 rail frame, sides near flat at floor level. Or spartin spartinette, pretty, flat sides, alum exterior. Was in a couple and interior height seemed more than airstream.
putback is offline   Reply With Quote
New member in Canada! Dreaming of an Airstream... lovespirit Member Introductions 2 07-14-2015 11:54 AM
Airstream Dreaming on a Winter Day jowenb Member Introductions 6 12-29-2010 05:11 PM
Dreaming of airstream rebel beck Community Polls 16 06-16-2010 09:29 AM
Looking - Dreaming - Got Question bevedfelker 1997 - 2004 Bambi 0 05-04-2004 11:47 AM
And we thought we were bored (dreaming of summer camping...) 67caravel Our Community 0 04-08-2004 12:58 PM
