Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 04-28-2009, 01:49 PM   #1
Burlington , Ontario
Dreaded scratch on the aluminum skin
Hi...I have a 2005, 25 ft safari SS and unfortunatley managed to rub it along the side of a corrigated pole. (makes a grown man want to cry!!)
The result was some scratches about 2 feet loong by 1/16 inch wide. I tried buffing it with protect all wax but it still has left noticable marks which seem to be etched into the aluminum.
Any suggestions how to restore it back to it's original shine???
Also a section of the rubber moulding was damaged. Is it easy to replace??
I can send an image if you needed.
Thanks, Bob Covey
salula is offline   Reply With Quote
Old 04-28-2009, 02:11 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Pictures would help,don`t know about the new aluminum,on the older models I`ve used very fine wet sandpaper to make them less noticeable.Dave
easyride is offline   Reply With Quote
Old 04-28-2009, 02:48 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Sympathy Karma!
Same thing happened first trip out on my 2006 Safari FB SE. It was an oncoming car on a narrow mountain road however. I have a 10 inch long scratch and a small crease in the aluminum.
So. I got some painter's tape (the blue stuff) and some "new formula" clear coat in a spray can from Jackson Center. I masked the entire area leaving less than a 16th of an inch on either side of the scrape and very very lightly sprayed the damaged area - repeating two additional times.
It's still a bit visible, but it hasn't gotten any filoform. I notice it, I doubt if others do. I could put a flag decal over it since it's on the roadside front panel just behind the stone guard.
I also got a very minor scratch on the inside aluminum, which I treated the same way. It covered well, but then that one doesn't have a dent.
Paula
Old 04-28-2009, 10:26 PM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Like this?
Paula
Hi, that's exactly what I did. Some dummy, on the way home with his brand new trailer rubbed against a car in a parking lot. [very bad feeling] I cleaned it up as good as possible and ordered, online, a flag decal to my specs.
Name:	My Picture CD 218 (Large).jpg
ID:	79404   Click image for larger version
Name:	My Picture CD 235 (Large).jpg
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 04-29-2009, 07:39 AM   #5
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Now that's an idea BOB. Kinda something similar happen here. Some dumb ass was loading a yard tractor on his flat bed trailer next to his Airstream without the flat being hooked up or chocked. When applying the brake on the tractor the trailer rolled forward and went left(has a dolly wheel on the jack) and the corner of the toolbox on the trailer hit the fridge access door and left a really nice scrap mark,an dent and paint on the door. Whats even worse BOB is this was rite here in my own driveway.
Now I have two choices wet sand and cover with a nice flag sticker like yours or replace the door. I think I like the flag idea.
You would think after 70 yrs I would know better and chock a loose trailer.
Thanks Bob
PS Do you remember where on line ya got the flag sticker.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 04-29-2009, 04:35 PM   #6
Thanks Paula..I'll try your trick with some New Formula Clear Coat. I have a very small 3" scratch I'll use as a test spot. Man-oh-man..it really hurts to see some marks on the Safari, but something tells me there will be a few more to come as the miles build up!!
Bye the way...what the heck is filoform??
Regards, Bob
aluminum skin question art Clearcoat, Exterior Paint & Trim 8 09-08-2009 09:38 AM
Aluminum skin scotty2 Ribs, Skins & Rivets 2 01-07-2009 02:59 PM
63 Bambi Aluminum Skin Gauge kamo Ribs, Skins & Rivets 13 11-22-2006 07:33 PM
Interior Skin Aluminum or Wood?? BornToRock General Interior Topics 5 08-31-2005 07:33 AM
Need a piece of Aluminum Skin Navigator Ribs, Skins & Rivets 3 01-08-2004 09:50 AM
