Old 12-08-2013, 11:48 PM   #1
1973 23' Safari
Sacramento , California
Drain Problem
We have a 73 Safari; and we were just up in Plymouth, CA ( up by foothills outside of Sacramento). It got down to freezing the first night and I did not know to take off the water supply hose. Naturally the hose froze! So I thawed it out and hooked it back-up and all worked fine. The next night I un-hooked the hose and we went to bed. The next morning I re-attached the hose and turned on the water; the faucets were working fine as was the hot water heater. I then noticed water was dripping out of a spout under the left rear of the trailer! Did not see any water inside the trailer, or it draining anywhere else? Would have thought if a pipe had burst there would have been water all over instead of just drips! Any help will be greatly appreciated!!
Thank you,
Carl
kaminski73 is offline   Reply With Quote
Old 12-09-2013, 12:37 AM   #2
Snedwid's Avatar
2011 23' FB Flying Cloud
Perry , Florida
"...water was dripping out of a spout..."
Can you elaborate on what the spout is for? If I understand spout correctly, its a leaky valve problem and not a burst pipe problem.
"If you don't know where you are going, you will wind up somewhere else." Yogi Berra
Snedwid is offline   Reply With Quote
Old 12-09-2013, 04:45 AM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I think that is a low point drain. Is there a cabinet next to the bed? Chances are there is a valve in there which is leaking. Might be open a but and the freeze opened it enough to leak a little?
Old 12-09-2013, 04:24 PM   #4
1973 23' Safari
Thank you all so much!! I found the valve you mentioned and it does go to that lower under floor spout. Found out it can be replaced at the shop in about an hour.
I have one more question: Do the older Airstreams like ours have a filter for the heater?
Thank you once again.
Old 12-09-2013, 07:12 PM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Filter for the propane furnace? Nope.
Filter for the integral AC heatstrip... yes of sorts. Its like a plastic gauze. Can be washed out and reused.
