Old 10-09-2014, 08:19 AM   #1
Full-timer
1971 27' Overlander
Pumpkintown , South Carolina
Door threshold screw source?
Doing subfloor replacement at the front door, and the screws in the door threshold are corroded, some broken, and seem fairly special. They're very wide head Phillips countersunk self-tapping metal screws, and I don't recall seeing their like at a bolt house. Does anyone here know where to find appropriate replacements? Thanks.
It's not the heat, it's the stupidity.
Foureagles is offline   Reply With Quote
Old 10-09-2014, 08:04 PM   #2
Mixter's Avatar
1976 27' Overlander
I found some at local Ace Hardware, that has a particularly good selection of Stainless Steel. I have not yet installed, so I cant say how well they worked, but they seem to be a great match to original.... I will likely have to touch up the counter sink a bit to match the bolt, so not sure how that's going to work- these philips heads are massive. I also bought matching nyloc's for the underside.
If they dont work the way I want, I should be able to find something else.
As for Ace's selection.... I happened to be near another one 2 days ago and went in to pick up some washers.... they did not have nearly the selection from my normal store. The employee said they are all independently owned franchises and therefore carry different products.
A great alternative is McMaster Carr online. They literally have everything. BUT sometimes I like to touch and feel.... Ebay also has been a good source of my Stainless Steel hardware.
Mixter is offline   Reply With Quote
Old 10-10-2014, 06:44 AM   #3
Full-timer
1971 27' Overlander
Thanks Mixter. I wouldn't have thought that they'd be common enough for a hardware store. I too prefer to physically compere something like that, and so I'll check. And we do have some pretty good fastener shops in the area.
Appreciate the tips!
"Soft"entry threshold. Loeber Repairing/Replacing Floor &/or Frame 5 11-24-2012 03:49 PM
Source for Glass Screw-in Fuses glang58 Electrical - Systems, Generators, Batteries & Solar 4 04-24-2010 08:08 AM
Does anyone know how I tighten this screw on the screen door holding clip? MikeDT Doors & Locks 9 04-18-2010 10:15 AM
threshold light 1992 sovereign dikku@mac.com Lights - Interior & Exterior 3 04-03-2006 05:49 PM
Rust at threshold of door bdogz Exterior Restoration Forum 4 08-28-2005 06:32 AM
