Old 04-10-2014, 12:36 PM   #1
Door swinging the wrong way?
Building a Canned Ham/Airstream mutant.
I have a door frame from an old donor canned ham. Before I install it don't you want the door to open from the left? hinged on the right? from the outside?
So that when you're driving down the road the wind won't catch it and make it fly open?
bass-o-matic is offline   Reply With Quote
Old 04-10-2014, 12:39 PM   #2
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Airstreams have "suicide" doors.
They open from the right and are hinged on the left.
Other brands usually have doors that open from the left, hinged on the right.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-10-2014, 12:48 PM   #3
reinergirl's Avatar
Hollis , New Hampshire
The opening of the door can also interfere with awning arms so if you are planning one please take that into account. Weld love to see pictures of your " mutant"
reinergirl is offline   Reply With Quote
Old 04-10-2014, 12:51 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
You probably want the door so it can open fully against the trailer without hitting the awning arm. That's the main factor. If you're concerned about it opening when going down the road, no matter which way it opens, put a rubber door stop through the grab handle alongside. Attach it to the grab handle for convenience by tying a lanyard through the stop and looping it through the grab handle.
Doug and Cheryl
Old 04-10-2014, 12:57 PM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Basically, if you have an awning, you don't want the open door to smack into the awning arm before it swings fully open. With the typical Airstream having an entrance door at the front, and the door under the awning, the door has to be hinged on the left side so that the door swings away from the awning arm, not towards it.
Since your trailer will be a hybrid, consider where the door will be relative to the awning arms, and then decide which way to make it swing.
There are several posts here on the Forums that detail different approaches taken by people who wanted to wedge their doors shut in transit to prevent the door from opening while underway. I'll leave it to you to search for them. Keywords "door" and "wedge" should do it, I think.
On edit, Reinergirl and dkottum have already said the same in fewer words. Dare I say, great minds…
Cats and ultraleather Airstream upholstery don't mix!
Old 04-10-2014, 02:45 PM   #6
Thanks everyone! I'm enjoying every little detail of this "little" hobby.
Old 04-10-2014, 02:55 PM   #7
I have some time to decide on this one. Curious. If I wanted to buy a Door Frame (would need to handle a screen door too)… is there a supplier? or should I just refurb the one I got? It's not bad. Aluminum. flat. My sides will be flat.
Old 04-10-2014, 03:19 PM   #8
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Dear Basso-
PICTURES. We want PICTURES
You want advice, we want PICTURES
Connect the dots.
Seriously, if it's in good condition, why not use it?
Please pretty please, post some pictures.
Paula
Old 04-10-2014, 07:07 PM   #9
Connect the dots.
I'd love to but there's nothing to look at yet. Just the pretty new deck. Or 500 feet of Aluminum C Channel?
It's totally being built from scratch… and my imagination. My imagination doesn't photograph well.
Water getting into fresh tank the wrong way grantb4 Fresh Water Systems 21 03-21-2012 08:25 AM
Why are some AC shrouds facing the wrong way? robwok Furnaces, Heaters, Fireplaces & Air Conditioning 3 02-22-2012 02:58 PM
HELP with Brakes- Wrong TV? Wrong AS? Flying Gypsies Brakes & Brake Controllers 7 07-24-2011 07:04 AM
What is 2 way vs 3 way fridge? Astrodokk Refrigerators 12 06-01-2005 03:33 PM
