Old 06-16-2016, 02:37 PM   #1
Morganton , Georgia
Smile Door Lock
I am looking for any assistance I can get concerning a door lock for a 71 Trailwind . I have only been able to find a $ 600.00 version out there, are there any other options.
Silverfox23
silverfox23 is offline   Reply With Quote
Old 06-16-2016, 03:00 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
What are you trying to achieve? Replace it, repair it.
http://www.vintagetrailersupply.com/category-s/307.htm
http://www.inlandrv.com/catalog/index.php?cPath=52
2004 Excursion 4x4
Old 06-16-2016, 08:21 PM   #3
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Name:	ImageUploadedByAirstream Forums1466126344.249736.jpg
This what I did. It's a $40 fix. Even if you re-skin the door, it's still cheaper than the old door latch
Matt
rugjenkins is offline   Reply With Quote
Old 06-16-2016, 08:22 PM   #4
1972 31' Sovereign
Open Road , North Carolina
Can anyone recommend a cheaper alternative to the 70-79 $600+ replacement door lock? I'm in the same position as Silverfox, and hoping to come up with something much less expensive, even if not period correct. Looking at Inland RV, Vintage Trailer Supply, and Out-of-Doors Mart I only see the replacement. Thanks!
ricksha is offline   Reply With Quote
Old 06-16-2016, 11:03 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Door Lock
To: silverfox23 and ricksha
What is wrong with the one you have?
Old 06-17-2016, 04:18 PM   #6
Morganton , Georgia
Thanks, can you tell me a little more about what you did. I am a novice to the RV world. I like your cost much better than the 600.00 dollar one. Again Thanks
Dick Schmus
Morganton, GA
Old 06-17-2016, 04:54 PM   #7
airdreamers's Avatar
1985 25' Sovereign
Venice/Nokomis , Florida
Images: 14
Silverfox23
If you could take a picture of your lock to be replaced it would be a help. I have a Airstream door lock, new, purchased on the Air Forums Classified and it was the wrong one for my AS. As it turns out I was not locking my lock as it was intended to be locked, so my lock is fine. My lock is the same as the lock in the picture of "rugjenkins", in post #3. Sent me a PM if this is the one you need!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 06-20-2016, 04:30 PM   #8
rugjenkins's Avatar
1975 Argosy 28
Silverfox
Here are more pics.
1st take off door interior skin by drilling out the pop rivets.
2nd. Remove the old lock
3rd. Patch old hole with patch extending pass original hole by 1/2 inch. Buck rivet new patch.
4th. Cut new hole in patch for new lock. Install lock
5th. Replace interior skin
Name:	ImageUploadedByAirstream Forums1466458158.057199.jpg
ID:	264847Click image for larger version
Name:	ImageUploadedByAirstream Forums1466458179.472795.jpg
ID:	264848Click image for larger version
Name:	ImageUploadedByAirstream Forums1466458197.933645.jpg
Matt
Old 06-23-2016, 12:12 PM   #9
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
What's wrong with your door lock?
Lots of replacement parts available for those KT locks which where standard on trailers of that era.
I've work on many of those and they are relatively easy to repair.
I've even had broken pieces welded and chrome plated.
desertair27 is offline   Reply With Quote
Old 09-15-2016, 12:24 PM   #10
Sanzurii
Sanzurii's Avatar
1967 24' Tradewind
Federal Way , Washington
1967 - 24ft Tradewind - Bargman Door Lock
My original door lock on my '67 was giving me problems a couple years ago and I replaced it with a $500 Bargman unit that I found on Ebay. Very pricy!!! Over the past couple years, I've been locked out of my trailer twice due to the lock malfunctioning and I'm searching for other solutions now.
I'd like to keep with the vintage look, but am much more concerned about functionality and durability now. I'm taking it in to the local Airstream dealer in Seattle to see what options they can find.
Anyone know of a durable and reliable lock that's been used on other Airstreams over the years?
Sanzurii is offline   Reply With Quote
Updated keyless entry lock BAUER LOCK sc17842 Doors & Locks 6 03-22-2016 10:53 PM
KT Door Lock/ Door difficult to close Streamy1985 1969-1971 Caravel 22 01-12-2016 07:41 AM
Door lock won't when door closed Savage68 All Argosy Trailers 17 06-12-2014 08:39 AM
Accordion Door For Bathroom and Door Lock - 1963 Jinji 1960 - 1964 Globetrotter 2 11-13-2013 08:17 AM
Door Lock Loose interior Lock Pin.. Bootsinister Doors & Locks 12 10-08-2012 11:19 AM
