Old 03-30-2014, 06:39 PM   #1
2011 28' Flying Cloud
Orillia , Ontario
Door lock
I was trying to find out if any one was having an issue with their door handle lock locking when door is shut.
I have had it at the dealer twice now for this problem since I was passing through and they can't seem to get it fixed.
I didn't know if airstream was having door handle issues with 2011 flying clouds.
geo
Rust is offline   Reply With Quote
Old 03-31-2014, 06:32 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
This has been an ongoing problem. Airstream won't acknowledge it and all dealers can do is replace the latch assembly with a new one, which doesn't help unless the one you have is unusually bad.
Inland RV has a friction washer kit that helps with the problem but that does not completely fix it.
Old 03-31-2014, 06:47 AM   #3
Ayr , Ontario
I had a weird situation last year where the handle would not open the door from the inside. I was locked in the trailer. I eventually got someone to open the door from the outside.
I took the whole unit apart and greased it and put it back together and it has continued working, but now I'm afraid it will happen again.
gator.bigfoot is offline   Reply With Quote
Old 03-31-2014, 06:52 AM   #4
I have never heard of a documented failure of that "fix it kit".
If there is, please let me know.
Old 04-01-2014, 10:25 AM   #5
Ayr , Ontario
Andy,
Is the "fix it kit" for the door handle locking? Or will it fix the issue I encountered where the handle just disconnected itself and would not unlock the door. Or are these actually the same issues? I certainly would like to prevent this from happening again.
Any light that you could shed on this would be greatly appreciated.
Walt
Old 04-01-2014, 10:27 AM   #6
Originally Posted by gator.bigfoot View Post
Andy,
Walt
The fix kit prevents the door from locking by itself, when you slam the door.
Old 04-01-2014, 11:53 AM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
I had my door lock once after I installed the kit according to the instructions. I believe I posted something about it on Airforums when it happened. Instead of trying to tweak the lock any further, I leave a spare key where I can get to it.
Old 04-01-2014, 04:54 PM   #8
Well I suppose there is a first for everything.
But as the wheels at Airstream said, tell those folks to quit slamming the door.
But, no complaints since the parts were provided "free".
Old 04-01-2014, 06:02 PM   #9
Orillia , Ontario
Lock
Mine locks when shutting and we don't slam it.
Geo
Old 04-01-2014, 07:52 PM   #10
Geo
Send us a SASE with 2 stamps on it and we will send you the lock out kit, no charge.
Old 04-01-2014, 08:44 PM   #11
KYAirstream's Avatar
Northeastern , Kentucky
Would someone be willing to post a pic of the lock that experiences this problem?
KYAirstream is offline   Reply With Quote
Old 04-01-2014, 10:48 PM   #12
Wise Elder
Jammer's Avatar
2010 30' Classic
That's kinda the way I see it.
But, people should be aware of the possibility.
Old 04-02-2014, 03:22 AM   #13
That lock is only on the recent years of Airstreams.
A 1979 lock is very different.
Old 04-02-2014, 04:04 PM   #14
Thanks Andy!
Accordion Door For Bathroom and Door Lock - 1963 Jinji 1960 - 1964 Globetrotter 2 11-13-2013 07:17 AM
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Door Lock Loose interior Lock Pin.. Bootsinister Doors & Locks 12 10-08-2012 10:19 AM
Door in a door '53 cloud inner door size. Flysoncloud Doors & Locks 13 09-18-2010 07:10 PM
Door latch/lock McGill Doors & Locks 0 06-25-2002 06:51 PM
