Old 05-22-2013, 12:21 PM   #15
Alparce's Avatar
1969 31' Sovereign
Olympia , Washington
Hello, I just purchased a 1969 sovereign with the same problem. I took the latch out and took it to a lock and key shop. They put a new door spindle in it with a shim to make sure it was centered. I used a glass door Knob with a set screw on the inside. I had to drill a hole in the spindle behind for a cotter pin the inside plate for a cotter pin to keep it from pulling out. But it looks cool and works great. About 20 bucks.
Alparce is offline   Reply With Quote
Old 05-22-2013, 12:47 PM   #16
Rebuilding an old lock, is some what OK.
But, since they would be 40 years old or so, they should be replaced.
Why????
When the rebuilt lock fails, the trailer most likely will be on a trip, and not in your front yard.
Then, you have even more trouble.
Best to be safe and secure, not sorry and unsecure.
Old 05-22-2013, 01:41 PM   #17
1969 27' Overlander
Delburne , Alberta
Originally Posted by Inland RV Center, In View Post
All we need is the trailer serial number to confirm the year.
Thanks Andy. I will get that tonight and send it to you.
enaj is offline   Reply With Quote
Old 05-22-2013, 04:23 PM   #18
1997 25' Safari
1973 25' Tradewind
Greenville , South Carolina
If you want to have the same lock back in your camper, I have some new in box Bargman L-100 and L-200. Contact me and I will be glad to help you.
R_whiten@hotmail.com
Rick
montanablue is offline   Reply With Quote
Old 05-23-2013, 09:27 AM   #19
1969 27' Overlander
Delburne , Alberta
Good Morning Andy
The serial # is I27D9J687.
Thank you
Old 05-23-2013, 12:43 PM   #20
Good Morning Andy
Thank you
Your Airstream is a 1969 model and would use the lock kit # 22320.
A 1963 Overlander named Moonraker! reinergirl 1960 - 1964 Overlander 702 08-28-2017 11:36 AM
New to me Overlander Northlander 1975 Overlander 10 12-04-2011 05:33 PM
Help! My '63 overlander need plumbing, hot water tank, and water supply tank! aprilr 1960 - 1964 Overlander 9 11-30-2011 08:52 AM
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 08:31 AM
