Old 01-04-2015, 09:14 AM   #1
2016 26' Flying Cloud
2011 25' FB Flying Cloud
reno , Nevada
Door Hinge Pin Rising
I have a 2007 30 ft Classic that the bottom door hinge pin keeps working its way up and almost out. I keep pounding it down but it will not stay. I have lined up the whole and put in a rivet, but it sheers it off. What can I do? I there a different pin that can be put in?
jomondnv is offline   Reply With Quote
Old 01-04-2015, 09:22 AM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
After your Airstream was made the company began installing a hinge pin with a slot in it for a keeper ring to hold it in place. You can get them from Airstream or their dealers, maybe others.
Doug and Cheryl
Old 01-04-2015, 09:23 AM   #3
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
The new ones have a small C clip on the pin between the door jam and door part of hinge to keep it from moving..
Old 01-04-2015, 09:34 AM   #4
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
When we bought our 2005 Classic 30 (used), someone had obviously had the same problem and fixed it by staking the pin in place.
i.e., going around the circumference of the pin at the top edge when the pin was in its proper position, with a center punch, and 'popping' it every ninety degrees.
It has never moved in the six years we have been using the trailer.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 01-04-2015, 10:13 AM   #5
George
2007 25' Classic
Calgary , Alberta
My 2007 Classic has the same problem. It was staked like Wingeezer's, but the pin is working its way past the old staking. Time to redo it.
George
2007 Classic 25'/ 2013 Cayenne GTS/ 2015 GMC 2500HD Denali
gwmc is offline   Reply With Quote
Old 01-04-2015, 11:09 AM   #6
Ayr , Ontario
I have an 07 classic with the identical issues, but with the top hinge. It was staked and I have staked it numerous times, but it keeps coming out. It has gotten so bad that now I cannot take a short trip without it coming out. I am going to drill and an adjacent hole and tap it and then insert a screw with a large head to capture the hinge pin. Hopefully that will work otherwise I will have to change the hinge.
gator.bigfoot is offline   Reply With Quote
Old 01-04-2015, 12:34 PM   #7
jackson center , Ohio
You don't have to change the hinge ,you can just order a new hinge pin with slot and c clip. You can purchase through any Airstream Dealer. They are pretty straight forward to change.
Schu is offline   Reply With Quote
Old 01-04-2015, 01:34 PM   #8
eheffa's Avatar
2008 25' Safari FB SE
Victoria , BC
Could someone post a picture of the new assembly?
Thanks.
-evan
eheffa is offline   Reply With Quote
Old 01-04-2015, 02:38 PM   #9
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
google "airstream hinge pin"
2012 Dodge Durango Hemi/AWD
Old 07-04-2015, 08:06 AM   #10
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Here is a good video for this topic:
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 07-04-2015, 04:09 PM   #11
2000 25' Excella
Northern , California
Do yourself a favor and buy the new, grooved pin with c-clip from Airstream. It's an easy repair. And there's no need to go through great lengths to remove the old pin (like drilling the underside of the hinge). Just let it creep up like it tends to do, high enough to get some side cutters on it, and you can lever it on out. The new pins work great.
There's a reason why it comes up: vibration. In California, it's caused by poor roads. But wherever, something is inducing excessive vibration. After you replace the pin(s), you may want to check to see that the hinge screws are tight (mine were not); you may want to check you're wheel balancing; or you may want to check your tires.
Kamiak is offline   Reply With Quote
Rising demand 4 tow Vehicles ArtStream Tow Vehicles 2 12-02-2006 07:23 AM
Top door hinge pin works out during travel? Kistler Our Community 4 06-20-2005 07:04 PM
Refrigerator temp rising over time HowieE Refrigerators 17 09-23-2004 06:16 AM
door hinge worn not the pin silver 67 Doors & Locks 5 08-11-2004 08:30 PM
Door hinge pin. wyhjr Doors & Locks 3 10-20-2002 03:36 PM
