Old 04-13-2014, 06:20 PM   #1
1976 31' Sovereign
Pueblo , Colorado
door handle broken
been having trouble closong door. now i can not open the door from the inside, the handle just moves up and down, how can this be fixed. 76 airstream sovereign.
Were can i get a repair manual
Thanks, B.
bmor24 is offline   Reply With Quote
Old 04-13-2014, 06:33 PM   #2
CHIEF THINGAMAJIG FIXER
1964 26' Overlander
bugtussel , South Carolina
That should be a KT lock. Airstream used them from1970 to 1977. If the main frame is intact everything else to rebuild them is available from out of doors mart. Go their website and look for KT Lock assembly and they have a very good pic and also tells you a few of the tricks to get them to work. Not for the faint of heart to rebuild as you will have to make a jig to hold the handle assembly once you have it on the bench to drive out the roll pins holding the handles on if you get lucky and don't have to drill them out. Good luck
Bugtussel is offline   Reply With Quote
Old 04-13-2014, 06:45 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Here is the LINK to the info at Out of Doors Mart. The complete lock is very expensive, but quite often can be repaired.
Aaron
WBCCI #XXXX AIR #2495
Old 04-13-2014, 07:20 PM   #4
1976 31' Sovereign
Pueblo , Colorado
Thanks for the link, how do i go about pulling it out without breaking it. It's hard to get out.
Old 04-13-2014, 07:30 PM   #5
1964 26' Overlander
It has been awhile since I took one out but I think you have to pull the inside handle off first and then you can remove the access panel in the door to take the screws out that holds it in
Old 04-13-2014, 07:47 PM   #6
1976 31' Sovereign
Pueblo , Colorado
so, then you are saying i have to pop the rivits? and then re-rivit it,? that is some hard stuff to re-rivit. there has to be an easier way. do you know where i can get a repair manual. i like this rv but without i makes it tuff to keep it up and a in good shape.
Old 04-14-2014, 05:59 AM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
There are reprint manuals available from Airstream. Not cheap but well worth the money. I have a 1975 trailer with the same lock. I will see if I can find that page and scan it for you.
Aaron
Old 04-14-2014, 06:31 AM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Here is the scan for the door lock removal. This comes from the 1975 AS Service Manual...
Aaron
Front Door Handle Broken skittles Doors & Locks 16 11-01-2009 12:38 PM
Broken Interior Door Latch Handle!!! Boaz1362 Doors & Locks 9 08-19-2009 01:26 PM
'84 Door Handle Broken dscluchfc Doors & Locks 5 07-15-2007 11:26 PM
Broken interior door handle Excellaphant 1987 - 1989 Excella 9 12-14-2004 02:08 PM
