Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 01-01-2017, 08:43 AM   #1
2015 23' FB Flying Cloud
Troy , Alabama
Dometic thermostatcsnd furnace problems.
I had the E1 error on the thermostat a couple of times this week running the furnace. It would go away with power down and start working again. Now we are camping and I notice E1 again and the furnace will not shut off. Remove all power and perform reset on thermostat. Now thermostat is showing a flashing zone 1 and lit zone 4. No options for HP or furn... so i pull inside cover off of AC and check phone connectors, there is an extra one in there connected to a black wire not connected so i swap them our. Reset thermo same same. What is my next step? Pull cover off top of AC and check dip switches? Maybe they have moved? Im lost and thankfully have a space heater.. thanks in advance.
Kelley
kgrenon is offline   Reply With Quote
Old 01-01-2017, 09:05 AM   #2
Naples , Florida
Kelley
Kelly,
Look to the little plastic RJ-11 phone union that connects the black data cable coming from the A/C unit with the gray cable coming from your t/stat. They fail on a regular basis and often need to be replaced.
The quickest way to check the integrity of the grey data cable is to connect another, known cable from the RJ-11 union right to the back of your t/stat. Be sure that the RJ-11 plugs are oriented correctly, as a standard phone cable will not work.
I'm sure that you can find the proper RJ-11 orientation either in your manual or on-line.
lewster
Old 01-01-2017, 09:53 AM   #3
Troy , Alabama
Yeah. I swapped it with the extra one that was up there. They very well could be both bad....they seem cheap.
Dometic M70 door problems. New Gasket? jmpratt Refrigerators 9 05-01-2012 11:28 PM
Dometic RM 60 cooling problems batt Refrigerators 2 08-01-2010 05:33 PM
JC With Problems, Same Problems Goin Home ncbambi 2008 Safari SE 3 06-23-2009 09:44 PM
Update on Problems Problems pjzuk General Motorhome Topics 4 09-04-2007 06:02 AM
Problems Problems Problems pjzuk General Motorhome Topics 6 09-03-2007 07:25 AM
