Old 01-03-2016, 02:45 PM   #1
2013 23' Flying Cloud
Bainbridge Island , Washington
Dometic Refrigerator RM2551 Door Latch Worn Out 2013 Flying Cloud 23D
My 2013 Flying Cloud 23D has a Dometic Refrigerator Model RM2551. There is a latch mounted to the top corner of the door, it hooks onto a very small piece of hard rubber that is clipped into a slot inside the door frame. That small piece happens to be light gray on ours. It half hidden inside the door frame, the part of it you can see is about 3/8" tall, 1/8" wide and 1/16" deep. It (was) a wedge shape allowing the latch on the door to slide over it, but catch on the backside.
On our lightly used AS this piece has lost so much of its material and shape that the door latch is no longer retained. Sitting still the magnetic door seal holds the door, but underway this isn't the case.
I am having trouble finding this part from Dometic or my AS dealer.
Has anyone had to deal with this? Has anyone a part reference of another fix.
Thanks!
2001 BMW X5 4.4i (TV)
2004 BMW 330/Ci 6-spd
2005 BWM R1200ST
1977 Cessna C177B
warmrain is offline   Reply With Quote
Old 11-28-2016, 06:01 PM   #2
I've found the part at the local Airstream dealer. This requires the refrigerator to be removed, at least pulled out some inches, in order to replace the latch from inside of the frame.
Has anyone done this, and perhaps can offer advise?
Best, Steve
2005 BWM R1200ST
1977 Cessna C177B
Dometic RM2551 (2008 unit) LPG Check Light Problem Ray Eklund Refrigerators 16 06-13-2014 10:50 PM
2013 Flying Cloud 23D has a large coil of unused AC truplex under the refrigerator warmrain Electrical - Systems, Generators, Batteries & Solar 11 10-08-2013 10:15 AM
2013 Flying Cloud 23D roll-up shower door won't latch closed warmrain Sinks, Showers & Toilets 9 10-01-2013 08:52 AM
2006 Safari Dometic RM2551... Crashes Ray Eklund Refrigerators 3 08-08-2008 03:01 PM
Dometic RM2551 refrigerator temp Safari64 Refrigerators 0 03-14-2006 03:47 PM
