03-21-2016, 03:16 PM
2016 16' Sport
Hilton Head
, South Carolina
Dometic refrigerator failed on first trip
Has anyone here experienced a similar problem?!
We bought our 2016 Bambi Sport 16' in February and recently took it to Florida for a shake-out trip. Refrigerator worked fine for a day and a half. But then the fan began to run 24/7 and the refrigerator started to get warm. For the next two nights we had to turn all the power to the trailer off overnight just to get some sleep, then turned it back on the next morning. By the time we returned home two days later, the refrigerator was barely cool and the ice was mostly melted.
My husband thought he felt warm air coming out of the vent initially. Later, when the fan ran continuously, the air from the vent was cool.
Obviously, it's still under warranty, but our dealer is a 7-hour round trip away, a trip we'd have to make twice... Has anyone experienced something like this with their Dometic fridge?
03-21-2016, 03:22 PM
2016 30' Flying Cloud
Tampa
That stinks. Sorry you are having issues with your Bambi.
I am new to Airstreams, but not to small RVs. I can't say I've heard of a similar early demise of a Dometic fridge. The ammonia-based absorbtion system seems pretty reliable to me.
Maybe some things to try?
Do you smell ammonia? That would not be cool, and would possibly indicate a failure of the absorbtion circuit.
Does the fridge have multiple (as in, DC, or AC, or Gas) operating modes? If so, have you tried them all?
Have you tried removing 'all' power from the fridge for a few minutes to allow it to reset?
All I can think of...sound like a trip to the dealer unfortunately.
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
03-21-2016, 04:32 PM
1986 31' Sovereign
Miami
Call Airstream and double check that the reefer is warranteed by Dometic. Answer should be "yes"
Have it fixed locally by a Dometic authorized repair facility near you (the website should help you find one)
There is nothing Airstream specific about the reefer -- any competent RV tech can sort it out.
We had our Dometic AC repaired on the road by an independent shop and there was no charge.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
03-21-2016, 06:12 PM
2016 16' Sport
Hilton Head
, South Carolina
No ammonia, operated in both modes but "died" while on shore power. Additionally the fan would not turn off even when turning off the power switch--we had to pull the breaker. Probably would have if we pulled the shore power, but it was midnight in Florida bear country and we weren't keen on a trip outside.
03-21-2016, 06:23 PM
Tampa
Well shoot.
But as 2916 said, maybe a local Dometic dealer can service it? Certainly worth a call to Airstream before heading down the road.
Concur on Fl bear country. Glad ASs have Alum sides after doing many hikes in tents.
03-22-2016, 01:34 PM
2013 25' International
Monrovia
Dometic Fridge Problems
We have a 2013 25' International in which the refrigerator didn't work properly for most of the two year warranty period. A couple of things we have learned: 1) be sure the thermistor (a small white clip with wire attached) is properly attached to a cooling fin on inside of refrigerator above top shelf. If thermistor isn't attached, refrigerator won't cool no matter if you're running on propane or electric. 2) If running on gas you should be feeling hot exhaust from burner at outside access panel. The problems Airstream diagnosed/fixed during this frustrating period included replacement of an electrical board, reattachment of the thermistor and eventually replacement of the thermistor itself... after eventually finding that the thermistor was not operating properly on an intermittent basis. I recommend getting to an authorized Dometic repair facility, because everything our Airstream dealership did had to be coordinated through Dometic anyway. Regarding the fan... there is an external cooling fan that comes on to cool external fins when temp exceeds something like 85 degrees. That fan can run a lot in warm weather and is rather whiny/noisy. We had an on/off switch installed so we can turn that fan off at night, which makes it quieter for sleeping; and then turn it back on in morning. Good luck to you. We had our first consecutive trips where refrigerator worked properly in late 2015 and early 2016, so are just starting to really enjoy traveling in the Airstream!
03-22-2016, 02:04 PM
2008 25' Classic
Full Time
When you get the fridge repaired you may want to replace that fan with a quieter model and put in an on/off switch. Airstream uses the Dometic fan probably.
http://www.airforums.com/forums/f425...lly-11811.html
Kelvin
03-22-2016, 07:46 PM
Corolla
, North Carolina
STOP THAT FAN NOISE. Fan is mounted to the trailer shell and the noise is amplified as such. Get two rubber isolation mounts (McMaster-Carr)with the same screw threads and place between the fan and trailer. You won't need the on/off switch as then there will be peace.
05-26-2018, 05:35 AM
DawnLuvsPossums
2016 16' Sport
Gainesville
Did Dometic end up taking care of this for you? Mine worked fine until just last week and I'm down to the wire on the 2 year warranty, so was hoping for a tip. Airstream won't help.
05-30-2018, 11:28 AM
2017 28' International
Baileys Harbor
, Wisconsin
On trip and when we switched to shore power the refrigerator got warm. Reading 60 on the refrigerator temp. Not sure why. But it was working before and we drove with it on LP and it was working. So we put it back on LP. But it wasn’t doing anything. (At least that I could see). So we followed these instruction from the manual.
1). The manual says to turn the refrigerator Off then On. Wait 45 seconds for it to light. If it doesn’t do this again. Do up to 3 times. What this does is bleed the lines. Sometimes air plugs the system. I also changed LP tanks since I have 2. It worked. It takes a really long time for it to get cool. If it says 60 on the refrigerator then it’s not cooling. But we waited and after about 15 or 20 minutes it dropped to 59 and we knew it was working. It took half the day and all night to get it down to 36.
2). We now have to try it with the electric. But not going to do that now. I’ll wait until I get home to test that. Don’t want to deal with it while we are traveling.
So you might want to try it again using the stop and restart again. Could be this simple.
