Old 07-17-2015, 06:07 AM   #43
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Any new air conditioner you put on will be less reliable than your Armstrong from my experience.
Lance
Top is offline   Reply With Quote
Old 07-17-2015, 06:33 AM   #44
johnamjr's Avatar
1970 25' Tradewind
parkville , Maryland
Yea that's what everyone tells me. But finding someone to fix it now seems to be an issue.
johnamjr is offline   Reply With Quote
Old 07-17-2015, 06:45 AM   #45
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
It is worth fixing. You need a commercial refrigeration repairman.
Lance
Old 07-17-2015, 08:12 AM   #46
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Originally Posted by johnamjr View Post
I am about to remove my Armstrong unit. Needs a fan motor. That's it.
How do you know it needs a fan motor?
Your profile says you are an AV tech. I see you are doing some rear end repairs on your TW. I think replacing an electric motor and checking electrical circuitry is within your capabilities. Nearly every part for an old Armstrong AC is available from Grainger.
Lance
Old 07-17-2015, 10:14 AM   #47
johnamjr's Avatar
1970 25' Tradewind
From grainger? I did not know that. I am an av tech. But I also know my limitations. Hvac is one of them. I have had two different Hvac guys look at it. Neither of them wanted to be responsible for working on it up on the top of the as. They also did not seem confident in doing work on it At all. Even if I put up the scaffolding. And my local Rv repair facility said to just replace it. I would rather have something that every Rv facility can work on when it comes to that.
Old 07-18-2015, 04:54 AM   #48
Baltimore , Maryland
I have a clients trailer out at a local shop having it's Armstrong repaired....
Old 07-18-2015, 05:27 AM   #49
johnamjr's Avatar
1970 25' Tradewind
Frank it John Morris in parkville. I have talked to you many times. I don't know why I spaced on asking you about it. Would you know anyone who wants mine? I also have a penguin drain kit new in box.
Old 07-18-2015, 06:48 AM   #50
The Armstrong is the last of the serviceable unites to be used. Now a days they just trash the unit no matter what breaks. This form of disposable items disappoints me so...
Old 07-18-2015, 07:14 AM   #51
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
If they aren't confident in fixing it, they shouldn't be in the business. It is as basic as air conditioning gets. RV techs don't work on AC units as a general rule. They will remove your old unit and install a new unit. I understand your thought process on this, but take a look at how many brand new or a few years old ACs are replaced around here. I'm sure that if Don above had fixed his Armstrong years ago, he wouldn't be fiddling around with another throw away RV AC unit.
I personally would rather have an AC unit that has proven to run for 40-50+ years and can keep on running with repair parts that are readily available.
But, if you chose to remove the Armstrong, I'd love to have it as long as it is carefully removed by Frank.
Lance
Old 07-18-2015, 08:06 AM   #52
1973 31' Sovereign
Poland , Maine
Unhappy Tough choice--replace my original Armstrong with new AC
Oh to be in my shoes. I have been following the many threads on the topic of Armstong AC replacement and AC replacement in general. Lewster! Adonh! you guys help to make this process so much easier..I am NOT mechanically gifted- but do fix some things. Tough choice to make. My AS is an original 1973 31' with very few changes to it. I just bought it last week. The Armstrong blows warm air, the compressor kicks on and off quickly, all operated on a Honeywell wall thermostat.
1. Some guys are strongly in favor of keeping the Armstrong and trying to repair it. That would be cool -except that no one wants to tackle it- or no one around here, is believable enough to me that they have the capability. How do I safely get an AC repairman on the roof of my AS?
2. Take out the old- and in with the new. OK- now do I get the RVP Mach 8, or the Penguin II? Both have their pros and cons..is it so close of a match that I am getting too bogged down in the small details?
3. Do I use the AS drainpan, or get the Dometic drain cup kit?
4. Do I route the drain line inside and be authentic (what if its blocked? I haven't had a chance to run the AC so I don't know if its working..)OR do I go against some threaders and let it evaporate outside?
5. If I get a new AC, I have to think about the thermostat now. Manual, Wall? Electronic, portable?Too many choices....lots to know
I dont want to make a mistake, and have a mess on my hands. I am almost ready to blow off the whole idea, and buy a few fans....
I would appreciate as much input from the community as possible to answer these questions- or be able to talk to someone on the phone? Call AS?
Shapmaui is offline   Reply With Quote
Old 07-18-2015, 04:41 PM   #53
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
When I first bought my AS it had a Coleman a/c in it. That unit died while I was in getting service at JC. Rather than mess around with the old unit, I opted to get a new one, which JC happily installed. About a month later we were camped at a white-water rafting resort for a friend's wedding. We had what we thought was 30-amp service, so we switched on the a/c - and nothing happened. I was sure that the unit had gone belly up, but I then noticed on the monitor panel for the Xantrex inverter/charger that when I attempted to switch on the a/c, the supply voltage immediately dropped from 115-volts to 85 volts. So the safety feature to prevent compressor motor burnout had been kicking in.
Sometimes getting a newer a/c does have some benefits.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 07-18-2015, 10:38 PM   #54
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Originally Posted by Shapmaui View Post
Oh to be in my shoes. I have been following the many threads on the topic of ............
Have an "RV"
Tech remove the unit carefully and install a new modern one.
Send the old one to TOP!!! He can get it fixed!
Any AC person can fix that.
cwf is online now   Reply With Quote
Old 07-20-2015, 06:13 AM   #55
1973 31' Sovereign
Poland , Maine
Hey CWF- just wondering why you say to get a new AC AND have the old one repaired? Would someone want the old Armstrong for rehab purposes perhaps? Because once I put in a new one- the Armstrong becomes dead weight to me I would think-
Old 07-20-2015, 06:16 AM   #56
1973 31' Sovereign
Poland , Maine
Oh - I'm slow- CWF- I see that you were joking about getting the Armstrong repaired....
