Old 05-27-2012, 03:56 PM   #1
1999 25' Safari
Ellijay , Georgia
Send a message via Skype™ to jdanielii
Dometic frig won't work on gas
I replaced the cooling unit and it works great on shore power. When I disconnect shore power with frig in auto it switches to gas and lites the flame. It stays lit for about 30 seconds then goes out, it reignites a minute or so later and goes out after 30 seconds or so. Is it normal to go off and on or should it stay lit. I replaced the thermocouple - didn't help. What could it be?
jdanielii is offline   Reply With Quote
Old 05-27-2012, 05:06 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
What brand, and how old is the fridge?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 05-28-2012, 05:00 AM   #3
1999 25' Safari
Ellijay , Georgia
It is a Dometic and it is vintage 1999 same as my Safari.
Old 05-28-2012, 06:51 AM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Have you tried adjusting the thermostat (if it has one) to a higher setting to find out if it will stay lit longer? You may have low gas pressure. Is the propane bottle(s) full? Do you have a good flame on the cooktop? Have you checked for a gas leak at the fittings on the refer?
