Access is dependent on your specific model and cabinetry, however, in almost all cases, you will have to pull the refrigerator out at least partially to have enough space to swap the element. The process is not too hard, takes little time, and can be done once on the road if you have to. It is a whole lot easier to pull out far enough if you empty it first ;-)
