Old 08-20-2014, 10:06 AM   #1
1976 31' Sovereign
Sandpoint , Idaho
Dometic Fridge?
Hi there,
Can anyone tell me about how a Dometic fridge works?
I have one out of my rig and want to see it is working. I plugged in the AC cord and nothing happens on the control panel. Does it require 12VDC for the AC side to work?
I'm guessing all the AC does is replace what the propane does when running on gas and that the fridge must have 12VDC at all times.
Pete
phoyt is offline   Reply With Quote
Old 08-20-2014, 10:09 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Yes the controls of the frig are 12 volts. Supply the unit with 12 volts and you should be able to test things out. Just make sure the frig it upright as this is important to the return of the refrigerant within the system.
2004 Excursion 4x4
Old 08-24-2014, 01:58 PM   #3
johncook's Avatar
2007 27' Safari FB SE
Mesa , Arizona
domentic frig
can anyone tell me where to get the shelf inserts for the freezer dore
johncook is offline   Reply With Quote
Old 08-24-2014, 02:33 PM   #4
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
If it is the original fridge, you don't need 12V. If it is a replacement fridge, then you probably need 12V.
Bill
Originally Posted by phoyt View Post
Hi there,
Pete
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 08-24-2014, 10:45 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
To the OP.
How do you know? Nothing happens.
An ammonia refer does not make any noise. Like the refer in your house.
It takes several hours for the refer to cool down.
The boiler on the back of the refer. Should get warm when you have it plugged in. The control set to electric mode and the thermostat set to at least 5 on a scale of 1 to 7.
Do you know the model number of the refer?
As stated. If it is original, it does not need 12 volts.
If you could post pics of the controls and the back side of the refer. It would help.
TG Twinkie is online now   Reply With Quote
Making a 2-way Fridge into a 3-way Fridge? Bunkroom Refrigerators 18 06-03-2014 04:37 PM
Fridge Vent and Fridge 12V DC wiring rodsterinfl Electrical - Systems, Generators, Batteries & Solar 1 05-03-2014 09:33 PM
Need Fridge...can Solar keep up with an Electric Only Fridge??? chowman2011 Refrigerators 13 05-17-2011 08:59 PM
Small fridge to large fridge ? 4tumbleweed Refrigerators 3 07-04-2010 06:44 AM
dometic fridge problem nightowlhooter1 Refrigerators 27 08-19-2006 05:06 PM
