Old 07-24-2016, 09:29 AM   #1
Morgan guy's Avatar
2007 27' Classic FB
Fredericksburg , Texas
Dometic AC Error Codes
At some time in the past I researched the Dometic Error Codes. I ran across them recently and thought it might be helpful to submit them.
E1 - Loss of comm signal between CCC2 thermostat & system power module board
E2 - Open circuit or out of range indoor temp sensor - Fan only will work
E3 - Shorted indoor temp sensor - Fan only will operate
E4 - Open circuit or out of range outdoor temp sensor
E5 - Open circuit or out of range freeze sensor
E6 - Open circuit humidity sensor
E7 - Loss of 120v power
E8 - Invalid zone config. Dip switches set incorrectly
E9 - Invalid zone config. Check dip switches
The Tex-i-can is Ready to Camp
Morgan guy is offline   Reply With Quote
Old 07-24-2016, 09:47 AM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Thanks. I'm embarrassed to ask - but where does one find these codes? Is it in the AC unit itself somewhere? Is there a diagnostic tool to connect? Thanks!
SteveSueMac is online now   Reply With Quote
Old 07-24-2016, 12:40 PM   #3
ooo
They're in the operator's manual for the thermostat and on Dometic's website.
tblkfsh is offline   Reply With Quote
Old 09-30-2016, 03:44 PM   #4
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Does anyone know how to remove the inside cover on the Dometic Penguin II units?
I am continually getting an E1 code.
It happens so often I think there must be a loose connection where the data cables to the 15,000 BTU unit and the 13,500 BTU unit where they are connected.
It is my understanding that to get to the data cables I must remove the inside cover.
The data cable from one unit to the other is supposed to be black and I know the cable to the thermostat is gray.
My understanding is that the connector looks like something you would connect ordinary telephone cables with and is in all office buildings and possibly even available at Walmart in the phone section.
I want to get this thing apart and look at it to see what I can do.
Dometic tech support is no help and I am too far away from a service center to have them look at the wiring.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is online now   Reply With Quote
Old 09-30-2016, 04:49 PM   #5
daveswenson's Avatar
2012 28' International
Issaquah , Washington
If I remember correctly the connection for the data cable is inside the trailer. Remove the Air Distribution Cover inside to access it.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 10-01-2016, 09:17 AM   #6
m.hony's Avatar
2013 30' Classic
I haven't found all the screws to remove the air distribution box.
I think there are 8.
1 front
1 back
1 each in 2 directional vents
2 each in 2 filter areas
TAC #MS-10
Airforums #70955
Old 10-01-2017, 12:05 PM   #7
2016 30' Classic
Cypress , Texas
Dometic refrigerator won't turn on after loss of converter
We had a complete failure of our converter in our Airstream 2016 Classic. We had roadside assistance the technician had us buy a battery to provide the power so we could continue to use the trailer until we could get a service appointment (it was completely dead with no charge to the batteries).
Everything was working fine with the trailer on a large battery charger, but now the refrigerator won't turn on and is flashing error code 4. Sometimes it flashes error code 3. We've tried running it on LP only, tanks are full, but it isn't turning on at all at this point. Any ideas how we could limp along and get it back up and running? Our first earliest service appointment is after a trip next weekend.
Thanks and would appreciate any ideas!
hurlimav is offline   Reply With Quote
Dometic refrigerator error code e0 lgring 2011 - 2015 International 0 02-12-2016 08:55 PM
Help: Dometic on heat shuts down; Error E3 LAWBC Electrical - Systems, Generators, Batteries & Solar 7 09-28-2014 01:23 PM
Dometic Error E7 S3d Sprinter and B-van Forum 4 08-27-2014 06:46 PM
Dometic RM3762 Error code E1 help Airstream01 Refrigerators 18 05-16-2013 09:43 AM
Dometic Comfort Control Center Codes fmrcaptevil Furnaces, Heaters, Fireplaces & Air Conditioning 41 10-21-2012 07:56 AM
