Old 06-23-2019, 02:27 PM   #1
Nod
1971 21' Globetrotter
Somewhere , Mississippi
Dometic a/c clanking
I used the search function but found nothing. Dometic ac started making a clanking sound when I turn it on. It will some time stop clanking and run smooth. I think I saw a thread on fixing this but cannot find it now that I need it. It is an old one but still cools just fine. Thanks for any help.
Nod is offline   Reply With Quote
Old 06-23-2019, 02:29 PM   #2
2007 22' International CCD
Might want to check under the shroud for a bad fan motor, bearing wear, or a loose object in the mechanism. Could be anything
Old 06-23-2019, 02:47 PM   #3
Nod
I plan to do that, I do wish I could find that thread. If I remember correctly it was exactly the same problem I have. Thank you.
Old 06-23-2019, 04:45 PM   #4
Dave-n-Janet's Avatar
Moss Point , Mississippi
We got a lot of clanking noises as well once, turned out unbalanced fan due to mud dauber nest. Took off shroud, scrapped off and all working fine again...
Dave-n-Janet is offline   Reply With Quote
Old 06-30-2019, 02:22 PM   #5
Nod
I finally got time to take the shroud off. It was mud dauber nest in the squirrel cage, one on the shaft and two on the fan. Strange how sometimes it would run fine and sometimes it wouldn't. Cheapest fix yet.
Charging old Dometic Reefer smily Refrigerators 9 09-18-2017 02:50 PM
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 18 03-21-2011 08:07 PM
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 03:36 AM
dometic 3way refer. will Refrigerators 3 08-23-2002 04:52 PM
Dometic Furnance Help cmgirdwood Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-07-2002 09:34 PM
