Old 10-30-2015, 01:43 PM   #1
2004 25' Safari
South West , USA
Dometic 5-Button Thermostat
I am trying to get the part number for the '5 Button' Dometic Comfort Control (LCD) thermostat in my Safari with a heat-strip/AC. It seems that there are at least 2 versions, one for a heat-pump & one for a heat-strip. I know these are no longer being produced but I'd still like to know the correct part number for it.
The number I come up with is: 3109228.001 but it's description indicates it's for a heat-pump system, no mention of a heat-strip. I'm not sure if there is a difference or just the way it's hooked up??. Mine does show "Heat-Strip" on the LCD display when using it.
Does anyone know where I can find out for sure?
RivetED is offline   Reply With Quote
Old 10-30-2015, 02:07 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
To my knowledge, there is only 1 CCC-1 model. You program the t/stat as to whether you have a heat pump or heat strip using the DIP switches the are located on the relay control board found on the curb side of the upper unit below the shroud inside an approx. 5 X 7 galvanized steel access panel.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 10-30-2015, 03:40 PM   #3
2004 25' Safari
South West , USA
Thanks lewster. You are right, according to my info, I'll know after the install. I was able to talk to someone at Dometic (not straight forward as a consumer) & confirmed the part number. There are different suffixes for white or black, not pump or strip. As you posted there is an initialization procedure/programming set-up for the new thermostat that will 'read' the DIP switches and set accordingly.
There's always something new to learn with my A/S.
Old 10-30-2015, 04:38 PM   #4
lewster's Avatar
If you don't have the re-set procedure let me know and I'll post it again.
Lew Farber
541-490-6357
replaced Dometic 4 button thermostat jasper2222 General Repair Forum 0 03-20-2015 06:24 PM
Dometic CCC 2 Thermostat (12 button style) Terratravels 2009-2015 Flying Cloud 12 10-22-2012 07:53 AM
Dometic on/off button problem Gene Refrigerators 2 08-06-2009 07:19 PM
