Old 06-19-2016, 02:55 PM   #1
2009 19' International
Alexandria , Virginia
Domestic Comfort Control 5 button
I just got my trailer out of storage. I plugged into shore power and my led on the control panel is blank. ON/OFF switch seems to have no effect. All was working well when it was placed in storage. Anyone have a suggestion? Thanks
Cdusm is offline   Reply With Quote
Old 06-19-2016, 03:02 PM   #2
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
The thermostat is powered by your 12 volt system so you most likely have other issues as well. If everything else is working, try a thermostat reset in accordance wth the instructions in your manual. Jim
Jim Flower is offline   Reply With Quote
Old 06-19-2016, 03:04 PM   #3
Thanks Jim, everything else appears to be working. I tried the reset with no success.
Old 06-19-2016, 03:44 PM   #4
New wrinkle, I unplugged from shore power. The LCD display came up. I plugged in and started air conditioning normally. It ran for a few minutes, screen went blank and it shut down.
Old 06-19-2016, 07:20 PM   #5
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
My experience is with a CCC 2, which is found on my 2012 Signature so I am not useful here. It does sound like the communication between your AC, the thermostat, your converter, and your batteries is mucked up. Maybe Lewster will chime in and you will receive guidance from an expert. Jim
Old 06-19-2016, 08:08 PM   #6
lewster's Avatar
Naples, FL , Hood River, OR
Sounds lime you are either having 12VDC supply issues to the upper board located in the roof A/C or communication problems from that board (which supplies the 12VDC power to your CCC-I) to the t/stat.
Remove the inner shroud on your ceiling and look for the red and black wires going up into the A/C check the connections for tightness and possibly even re-make those connections with a proper crimp connector and tool. Also check the fuse that supplies the power to the A/C unit. I would change it regardless, as you need to be certain that the upper control board is getting full and proper DC power. I would also check the voltage there to be sure that it is receiving 12.5+ VDC. If you are plugged in, you might see up to 13.6VDC from the converter. This is fine....but nothing lower than 12.0VDC. If you see this, you have other issues with your DC voltage supply (battery) system.
You will also see an RJ-11 union where 2 phone-type plugs enter it. One wire will probably be gray and the other black. I would also replace that union, as they are a known source of problems.
After all of this, try your unit again to see if it comes on and stays on. If it is still having 'issues', it might be the upper relay control board and might need replacing.
\Of course, there is also the possibility that the CCC-i itself is intermittent and needs to be replaced. This is very difficult to test without another t/stat. If I was there doing the diagnostics, that is the first step I would take as it is also the easiest. All of the other steps would come later............
Old 06-20-2016, 07:56 AM   #7
Thank you, Lewster! You have given me lots of possibilities. I'll check back with the results.
Old 06-20-2016, 07:12 PM   #8
Lewster,
It appears the RJ-11 Union is the culprit. I checked everything and as I wiggled the union, the LCD came to life. THANK YOU!!!
Thank you, Jim!
Dave H
Old 06-20-2016, 10:38 PM   #9
lewster's Avatar
Domestic A/C,heat control box Martin R Electrical - Systems, Generators, Batteries & Solar 1 10-15-2015 07:04 PM
Duo-Therm comfort control module Gavin Winter Living 3 08-16-2009 07:09 PM
Comfort Control Center jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 8 12-15-2003 03:19 PM
