Old 06-24-2015, 08:57 PM   #1
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
Domestic 3314080 (twin zone) thermostat
I think my Thermostat has the 2 IN temp sensors wired to the wrong zones (I have the twin AC units). Anyone have the wiring diagram or know how to swap them over. I would think it would just be a case of swapping a few wires? Thanks.
2015 27FB International Signature "Danielle"
ProPride / 16" wheels / 600W solar / 864 AHr Lithium
Victron MultiPlus Inverter / BlueSolar / ColorControlGX / BMV 702
Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Old 06-24-2015, 09:21 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
The temperature sensors are directly connected to each unit. They are a little dome with about 3 or 4 slots in them. Since you have ducted air and no access to the under side of the unit where the wrong joins from the trailer, you have to remove the shroud, then the evaporator cover to find the wires. The wires for the temp sensors are run thru the roof and inside the skins. The probability of you 'switching' the wires is zero.
It might not be the temp sensors that are the problem. The A/C units might not be set on the proper zone, which would give erroneous readings and operations.
What exactly is the problem?
Old 06-24-2015, 09:31 PM   #3
1974 Argosy 20
Kooskia , Idaho
With a 2015 unit, I would think it is a warrantee problem, best solved by Airstream, unless it is a simple programing or set up issue as Lew suggests could be possible.
Old 06-25-2015, 05:11 AM   #4
Ohiobrits's Avatar
Howard , Ohio
Thanks lewster, I'll have a play around with it later and write down exactly what the issue is (family is sleeping right now). Having the wrong AC unit assigned to a zone sounds like it may be the issue. I think I read somewhere that the wiring for these units is via a flat phone line type cable, if so, are RJ type connectors used at the thermostat and AC units? If so miss wiring is probably hard to do?
idroba, yes it's under warranty.....but I like to tinker, understand how things work......I can't help myself :-)
Thanks.
Old 06-25-2015, 12:33 PM   #5
gwg
gwg's Avatar
2015 30' Classic
Glen Mills , Pennsylvania
Zone #1 is always the room the stat is located in.
gwg is offline   Reply With Quote
Old 06-26-2015, 09:27 AM   #6
Ohiobrits's Avatar
Howard , Ohio
Thanks gwg, that helped me get it straight. It appears the "problem" was operator error on my part :-) All appears to be working as it should. I will say though that the temp set point for the 2 zones need to be significantly different for the temp to feel about the same at both ends, I guess that was what was getting me confused. I have zone 1 (front) set at 76F and zone 2 (rear) at 86F and both areas feel about the same temp. I really don't need both running but was trying it out. We are in SC right now and it's pretty hot but we have plenty of shade so no problems with the cooling keeping up.
All, thanks for the help!
Old 06-26-2015, 09:30 AM   #7
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
If like mine the zone 2 sensor is mounted on the wall adjacent to the fridge, it is probably picking up heat from the fridge and giving that very warm reading. Joe
jayseejay is offline   Reply With Quote
Old 06-26-2015, 12:24 PM   #8
Oh SNAP!
Have had similar twin A/C thermostat issues in my 28 AS Serenity... Set both zones to 75. Zn 2 eventually stops & Zn 1 keeps running even though Zn 1 feels chilly and Zn 2 is warm. I'll check to see where my Zn 2 sensor is.
Also, I had the same suspicion about sensor wires being crossed, but tech checked it out and said everything was OK.
Krusty Buns is offline   Reply With Quote
Old 06-26-2015, 02:02 PM   #9
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
I took the cover off my zone 2 sensor and pulled the wire away from the warm wall adjacent to the frig. It is now dangling behind the Televison and we r getting accurate readings. I was going to ask airstream to relocate it so it's not just dangling but it's working now
Hiho Silver is offline   Reply With Quote
Old 06-27-2015, 06:33 AM   #10
gwg
gwg's Avatar
2015 30' Classic
Good to know about the temperature variations I thought my back unit was not working properly. Next 50 Amp hook up this weekend I try it out.
Old 06-28-2015, 06:40 PM   #11
Ohiobrits's Avatar
Howard , Ohio
This forum never ceases to amaze me with the collective "hive" knowledge that is accessible by a simple post. Amazing.....
Which one is zone 1 and zone 2? Doc Foster Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-23-2017 10:52 PM
Dometic thermostat zone 1 Tino643 Electrical - Systems, Generators, Batteries & Solar 17 10-13-2015 03:40 PM
Wiring a Penguin II with single zone LCD thermostat 66replica Furnaces, Heaters, Fireplaces & Air Conditioning 6 12-08-2014 08:32 AM
Dual zone thermostat? matthorr Furnaces, Heaters, Fireplaces & Air Conditioning 11 06-30-2013 07:40 PM
Leak no more - tales from the toilet zone janetb Sinks, Showers & Toilets 11 05-14-2007 03:57 PM
