Old 11-21-2008, 02:07 PM   #1
dreadydreame's Avatar
1965 26' Overlander
Newport , North Carolina
do it yourself restoration help
Hello, My husband and I just purchased a 65 overlander and we are needing to replace some of the flooring in the bathroom and the belly pan, we don't know if the blackwater tank will also need replacement. We are willing and hopefully able to fix all this ourselves but we don't really know where to start. We need to know how much of the floor to cut out.
We are in Eastern NC and if someone with knowledge of this is willing to look at it and tell us what to do it would help so much.
also if there are people who would be willing to do some over the telephone help we would appreciate any we can get.
Please point me in the right dirrection as to websites or books that would help.
dreadydreame is offline   Reply With Quote
Old 11-21-2008, 02:26 PM   #2
azfiredog300's Avatar
Surprise , Arizona
Go through this forum and use the search engine alot. You can pretty much get anything you want here. Welcome aboard
Jerry C.
"Travelstar Galactica"
WBCCI #13317
AIR #25664
Member of the Four Corners Unit
The only true failure is the failure to try.
azfiredog300 is offline   Reply With Quote
Old 11-21-2008, 02:42 PM   #3
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Spend time on this website. It will be very helpful in your education.
1956 Flying Cloud - Restoration
Good luck and welcome aboard!
ts8501 is offline   Reply With Quote
Old 11-21-2008, 02:53 PM   #4
Hi dreadydreame, congratulations on your purchase and welcome to the Forums!
I have a 1963 Overlander which has many similarities with yours, and I've just begun a frame-up restoration of the back half of my trailer. These trailers tended to leak a lot through the back window and around the rear bath, so I suspect you'll need to replace at least the back sheet of subfloor, or you can alternatively think of that as the rear 4'. I'm going to go ahead and replace the rear 8' (two sheets), because I'm adding a gray tank as well (Airstream did not include gray tanks before around 1974 I believe).
To determine where you have floor rot, open every cupboard you can, and take an ice pick or an awl and push it into the floor. Anywhere it penetrates, the wood is rotten. Try to get as far our toward the outer shell as you can, because that's usually where the most damage is from leaks. If they are only very small areas of rotten wood (a few inches across), then you might be able to get away with patching it using a product like Rot Doctor. If they are as big as a foot, sometimes people are able to cut out the bad sections and scab in new plywood. But if your rot issue is several feet, then you're going to need to replace entire panels of subflooring.
You should also try to remove carefully the bellypan in the rear area, and inspect the frame. Chances are you'll have some frame rot (heavy rust that eats through the metal, rather than only superficial rust). If you do have frame rot, then you should cut out the old rusted steel frame pieces and replace with new material. If you don't have access to welding equipment, you'll need to take it to a shop. After you address the frame issues, then you can put in a new subfloor and replace the bellypan.
I'm not trying to scare you, but these old trailers tend to have these problems, especially at the rear end. Much better safe than sorry.
I think the absolute best place to start, for anyone who is about to do a major renovation job, is with the major renovation threads. I've linked them below, and some of them are lengthy, but read as much as you can and most of your questions will be answered.
http://www.airforums.com/forums/f44/...ons-35399.html
Good Luck!
Old 12-06-2008, 09:29 PM   #5
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
Greetings!
Just wondering if you were successful with your gray water tank installation, and if so how did you do it? I would like to put one under the floor, but do not want to do any work to the belly as it is in excellent condition.
Thanks!!
FLYNCLD is offline   Reply With Quote
Need Restoration myfavrv74 1974 - 1979 Sovereign 10 12-09-2009 07:01 AM
Do another restoration? boatdoc Trailer Values 8 03-07-2008 06:48 AM
Another Restoration... Pecos Pete Our Community 3 06-11-2007 08:27 AM
considering a restoration tim oleary General Interior Topics 1 01-01-2006 11:27 PM
How much restoration do I do? juel All Argosy Trailers 7 03-07-2005 10:09 AM
