Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 07-22-2016, 02:17 PM   #1
Do I want to vent my fridge to the outside?
I'm putting in this fridge...
http://www.edgestar.com/BWC90SS-Edge...efault,pd.html
It's going to be right up against the back wall. Maybe 2 inches of clearance from the wall. Do I want to put in a vent and blow air out the side of the trailer?
bass-o-matic is offline   Reply With Quote
Old 07-22-2016, 02:41 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
No. It's all-electric and does not need to be vented to outside since there is no combustion happening. The owner's manual (which I downloaded from your link) says the unit only requires 2 to 3 inches of clearance all around for ventilation. In that regard it's no different from a home refrigerator.
Old 07-22-2016, 04:09 PM   #3
Why thanks! That was very kind of you to go to the extra trouble. Well, I might have to put it an inch from the wall. Maybe i'll just get a little PC fan to blow some air back there?
Old 07-22-2016, 08:44 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Note: specs say it is free standing. NOT DESIGNED FOR BUILT IN APPLICATION.
Old 07-23-2016, 05:13 AM   #5
1964 24' Tradewind
2006 39' Land Yacht 396 XL
Lawrence , Kansas
I installed one with a tighter fit than called for in specs. To off set the tighter fit I left the old vent system in place and it worked for me. I build it in and had about 1 1/2 in on sides but 4 in in the back.
ttbikes is offline   Reply With Quote
Old 07-23-2016, 11:12 AM   #6
Tampatomgirl
1990 34' Excella
Zephyrhills , Florida
I installed a small residential refer in the same place as the old refer. Fully insulated the opening and left the original vent in place for the heat to escape outside instead of in my rig. It's difficult enough to cool in the heat of summer. Adding additional heat doesn't make sense.
Tampatomgirl is offline   Reply With Quote
Old 07-23-2016, 01:17 PM   #7
2012 23' FB International
Woodstock , Ontario
The cooling coils are most likely distributed around the sides and top like some of the small inexpensive fridges rather than having a forced fan system.You can't enclose it in or the heat will build up around the fridge and it won't be able to cool. Hence the free standing only designation.
JCW
JCWDCW is offline   Reply With Quote
New Fridge, Old Fridge Vent TMT Refrigerators 0 10-17-2015 07:23 PM
Fridge Vent and Fridge 12V DC wiring rodsterinfl Electrical - Systems, Generators, Batteries & Solar 1 05-03-2014 09:33 PM
Can you vent a battery through the fridge vent? Mike&Ali Batteries, Univolts, Converters & Inverters 22 03-07-2011 09:06 PM
I want new Fantastic Fans but I dont want to give up the lights. memgrove2000 Roof Vents, Skylights & Fans 4 03-10-2009 09:21 AM
