Old 09-22-2013, 02:22 AM   #1
Stream_tRVlr's Avatar
2011 20' Flying Cloud
Stamford , Connecticut
Disappointed....woke up to a leak
So my fiancÚ and I have always dreamed of owning an Airstream. Well it became a reality a week ago when we picked up our used 2011 FC20. I posted last weekend after we woke up to a drip from the fan above the bed but found out from the forum friends here that it just condensation. Weekend #2....steady rain here in Massachusetts where we are camping and I don't believe what I just woke up to is condensation.....
Stream_tRVlr is offline   Reply With Quote
Old 09-22-2013, 02:24 AM   #2
Old 09-22-2013, 02:30 AM   #3
A leak in between the reading lights. I looked under the bed and there is some moisture on the floor along the wall. What has me concerned is I have no warranty. I've seen people online talk about newer Airstreams that have leaks that lead to floor rot.
Sorry for the 4 a.m. rant I'm just really bummed to wake up to see this.
I guess my next question would be a good dealer in the CT or MA area to look at it before we head out on our honeymoon with this in a few weeks.
Old 09-22-2013, 02:48 AM   #4
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
They all leak!! Eventually
You need a leak test.
http://tour.airstreamlife.com/weblog...leak_test.html
Not sure what's in your area.. closest might be Colonial Airstream in NJ.
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 09-22-2013, 04:37 AM   #5
65CV's Avatar
Western , Massachusetts
Classic RV may be able to do it, avoiding the bridges and city traffic. See this thread for reviews and details.
If you want to leak test it yourself, search this forum for "hillbilly leak test" to find ways that people have used leaf blowers to pressurize and test.
65CV is offline   Reply With Quote
Old 09-22-2013, 04:48 AM   #6
Danbury , Connecticut
Just had my stream "leak-proofed". In Southington, CT..Heritage Hills RV. They do the test...seal all seams that need it...then re test.
charliejw is offline   Reply With Quote
Old 09-22-2013, 05:00 AM   #7
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
You should be able to easily look under the bed at the floor edges to see if there are any water stains on the wood floor. The vinyl flooring is probably curled up at the edges (that's completely normal) so you can see the wood. I check the edges at least annually. Don't despair, we've had a few leaks too, the problem is when you don't catch them and they continue for a long time.
Old 09-22-2013, 05:46 AM   #8
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Just a SWAG, but I think you should look closely at the base of the Fantastic Vent. They are not always sealed with a huge amount of sealant, and sometimes the base will develop stress cracks in the corners.
Old 09-22-2013, 06:02 AM   #9
Full Time Alumaloafer
louaxtjr's Avatar
1966 24' Tradewind
Livingston , Texas
Images: 12
Don't be discouraged. As good as Airstreams are, they need regular maintenance. An annual inspection and reseal of questionable areas should be done. My rig is MUCH older than yours, but I've found the vents to require attention every time. These frequently leak but the water runs down the outside of the inner skin until it hits a seam, resulting in something like what you have.
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
louaxtjr is offline   Reply With Quote
Old 09-22-2013, 04:03 PM   #10
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I've had seams fixed on my AS just after I got it. I had made an appointment to have it checked at Jackson Center. They found and fixed it.
Depending on what your travel plans for your honeymoon are, you could decide beforehand to pass by JC and have it done while you wait - you would stay at the terraport (the JC factory service area with full hookups). What I like is that you don't have to leave your trailer there and then come back weeks later - they start on your rig first thing on the morning of your appointment and work on it until it is done.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 09-22-2013, 04:59 PM   #11
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
It will work out. Rent the movie the Long long trailer and laugh out loud!
Old 09-22-2013, 05:43 PM   #12
Fly at Night's Avatar
2010 27' FB Flying Cloud
Fraser Valley , British Columbia
Baby, a Little Rain Must Fall....but Do Not Despair!
That initial leak freak is normal. But as others have posted, get it fixed and carry on.
I have had a couple of minor leaks, but they were resolved via my dealer and haven't had another one for almost two years now.
Don't let it ruin your honeymoon!
Fly at Night is offline   Reply With Quote
Old 09-22-2013, 06:39 PM   #13
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
All RV's leak - Airstreams are no exception despite the higher cost! Moving down the highway, things flex and move and eventually caulking gives way. You can't compare it with a house!
I'm sure you will be able to find and fix the leak. It may be at a spot other than where you first suspect though - water can find unusual paths once it gets into a trailer before it actually makes its presence known!
After you find/fix it, You will find it worth doing a check of all caulking once or twice a year (including the roof) and addressing any areas that are starting to look suspect.
Even that doesn't guarantee the odd unpleasant surprise, but it will at least reduce the frequency!
Don't let it bother you - but do keep it in check, floors only rot when leaks are left
un-repaired for a long time!
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 09-22-2013, 06:53 PM   #14
wolverine's Avatar
2005 31' Classic
Sunrise Beach , Missouri
You might also want to check your skylight in that area. The factory installed skylights are notorious for developing cracks and leaking because of their poor design. Many airstreamers have replaced their factory skylights with Maxxim skylights to correct and prevent leaks. Their are several good posts on how to replace them yourself if you find that is what's causing your leaks.
wolverine is offline   Reply With Quote
