I previously started a thread about JC not winterizing my trailer correctly.
In all fairness to them, they were great taking care of that issue.
The reason that I had the trailer to JC in the first place was to repair some sheet metal damage to the trailer at the lower corners of the front storage compartment above the A-frame.
Somehow, that didn't quite pan out like expected either. The repair required the storage compartment door be replaced. It was replaced. This past week when we finally drove in the rain, so much water got into the storage compartment that it looked like someone took a garden hose with a sprayer on it and hosed it down. After looking at the door more closely, the hinge was not attached to the door correctly, resulting in the bottom of the door being held away from the seal somewhat.
I know JC will take care of this too. They already told me this. All I have to do is drive the 4.5 hours one way to get the trailer to them and wait for them to fix it.
I ran it completely around the perimeter of the door so that it will contact the weather seal that is already in place. I had to adjust the latches at the top of the door to get it to close properly. I guess I will see if it works short term until I can get the trailer back to JC.
Anybody have any other suggestions about fixing this temporarily?
We had our forward storage door (27FB) serviced repeatedly and even replaced with a door that uses two latches. Still leaked. We finally did pretty much the same thing, using EDPM rubber weather stripping from Lowe's to get a better seal all the way around. We used two different thicknesses to get optimal seals everywhere, as the space around the door varies from top to bottom. So far, that extra work has stopped nearly all the leaking. It's probably time for us to replace those seals to ensure a continued tight fit, but it's the only thing I've found that actually works.
Hmmmm, this is the exact problem we have with our 2009 27FB. I haven’t been able to diagnose exactly how the water comes in past the seal. I’ll have a look at the hinge.
Walt
2018 28 International Serenity
2013 F150 Ecoboost
Wow... something to keep an eye out for. If Rocinante can do it then we all surely can try as well
Cheers
Men are but men, and the greatest men are they who soonest learn the simpler things. ROBERT E. HOWARD
What a man does for pay is of little significance. What he is, as a sensitive instrument responsive to the world's beauty, is everything! H. P. Lovecraft
Did the same on the rear of my classic. Works well.
-Rich-
Here are pics of the hinge, and my "fix", with the profile of the weather stripping I used.
You can see in the door pic with the red circle how the hinge is not positioned correctly on the edge of the door. Holding the bottom of the door out. It was that way across the entire bottom of the door. You can also see the area immediately adjacent to the hinge where there was "blow by".
My fix was the weather stripping with the wider foot print, a littie more solid feel to it. My thought being it would seal better against the existing. I did need to adjust the latches. Time will tell.
Next time I drive in the rain... crossing my fingers.
Looks awesome! We used white EDPM and put it around the edge of the door, but backing it up with black EDPM the way you did would be a great enhancement. Off to Lowe's I go, for more EDPM before we tow extensively in the rain next Tuesday!
2016 27' Flying Cloud
Hendersonville
, North Carolina
All I have to add is similar disappointment with JC service.
I drove 8 Hours one way to drop off my 27fb for several warranty repairs because of all the great success I have read about on the forums. They would need it for a week or two in order to fix the issues I had so I dropped it and headed back home. Two weeks later I made the trek again to pick it up and then all the way back home. When I arrived home, after the first rain storm, water still poured from my AC intake vents like a waterfall.
Oh yes, bring it back for us to try again... I think not.
I can confirm all other repairs were made to my satisfaction, however this was the biggest issue and left me very disappointed.
Hope this helps others to deal with this problem.
Blair
Blair,
I would look for a drier place for the torque wench.
I feel so fortunate to not have had any issues that required a trip to JC (about 1,200 miles), and equally fortunate that I have an RV repair shop within 30 miles that I trust (if I can't fix it myself).
Hello? Airstream Ambassador? If you are monitoring this, I might suggest that someone simply telling a patron to "bring it back" isn't creating any goodwill. They've already taken time to take it, leave it, and return to pick it up, all at their own time and $$ expense. Someone didn't do their job correctly, and in this case, QC didn't adequately check for leaks post "repairs". If it has to be brought back because of faulty repairs, AS should at least reimburse the customer mileage at the current IRS rate. Just sayin'.......
Wow, I just returned from a 1,072 mile (each way) from Jackson Center and I am absolutely delighted with the work that was done on my 2017 Classic. I had 2 major issues and 18 very minor problems that needed to be addressed. All 20 issues were fixed or repaired completely and everything worked great for the 1,072 mile trip back home and is still working perfectly today.
I was able to watch as they worked on my wounded end cap and panels, watched as they installed 2 Maxim skylights for me, watched while they repaired a pierced elbow joint that was a result of a design flaw, was there on site while they worked through and implement design changes to all new Classic twin, watched while they installed a new multistage converter for me and showed me how I could do it myself if I needed to next time, I hung around all week and was encouraged to ask questions and they were extremely helpful with their knowledge, skill, hard work and customer care. They asked me each morning if I was happy with the work that was completed the day before. I plan to make the trip back to JC once a year if needed.
I am still relatively new to the while RV world and still have much to learn but I am not afraid to get in there and get my hands dirty to repair or replace minor little things as they pop up and I know they will pop up.
Should I ever need serious repairs or advice it is nice to know that the hard working, dedicated employees that I met in Jackson Center, while I was there for 6 days, will be there for me in the future.
Would I have driven 50 miles out of my way for a broken seal? Probably not, but if it’s something I can’t fix I know where to go.
Sorry your experience was different from mine.
In all fairness to Airstream, they did offer to send out RV roadside assistance if that's what I wanted. But I really don't think that would have resulted in an acceptable outcome for me. Just me probably being picky. I did decline their offer, my choice. My fault for not being clear on that part. Sorry.
But in my case it was 2 of the 3 things I asked them to do didn't work out right. That's my frustration.
Hi, this is a fix for leaky storage doors that I did several years ago and it has never failed. I bought what I call double D weather seal and install it all the way around the outer rim of the door. In the pictures, I originally only did one side but later did the other one. On our trailer we didn't have a water leak situation, but rather cold air leaking under our bed. These seals made a huge difference.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Thanks for posting the pics of how you fixed your storage doors. The gap on my door was rather large so I wanted to try mounting a wider seal (slightly stiffer) seal where I did to bridge the gap. Drove 3 hours in the rain on Friday, so far so good. No leaks!! I am going to add the extra protection like you and Rocinante have put on your doors.
And Bob....the torque wrench is in a much better place.
Thanks for sharing all, can see this being good to see info for most folks.
