Old 12-14-2018, 11:02 AM   #1
Annapolis , Maryland
Disappearing sewer hose
I am one step closer to my Charlie Foxtrot merit badge.
Having determined that it was time to finally use our undercarriage hose storage, I loaded our sewer hose extension into the storage tube. Happy to find that it fit perfectly. I “secured” the tube cap and hit the road.
Within a day, the cap disappeared, as did the hose - somewhere between Dodge City and Tucumcari.
I imagine the red hose snaking out of the tube provided entertainment to someone, although traffic was light and no one applauded.
Not to be outdone, I purchased a new tube cover and tail, and inserted a new hose extension. I tightened the cap with a channel lock pliers and added electricians tape. I’m hoping to get two days out of this set up.
rhpeahl is offline   Reply With Quote
Old 12-14-2018, 11:40 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Had a similar thing happen with an extra hose that tried to escape on I-10 between Sam Antonio and Katy, Texas. We were alerted to the dragging hose by numerous drivers who passed us waving and pointing to the rear of the Airstream. I can only imagine that some of the passing people may have thought we had forgotten to unhook the hose when we pulled out of our last campsite.
We were able to salvage a few feet of the never used sewer hose that we now use with our blue tote.
Richard
Old 12-14-2018, 12:11 PM   #3
2018 28' International
Fayetteville , Georgia
I lost a hose that way, too. Cap does not seem to be tight.
brick
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 12-14-2018, 12:17 PM   #4
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
The cap is secure if inserted correctly. It can easily inserted with only one tab properly in place. Mine is not a threaded cap and using pliers is not required and won’t make it any more secure.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 12-15-2018, 01:57 AM   #5
2016 30' International
redondo beach , California
Kudos to Airstream for sourcing the absolute cheapest cap on the market.
Randy and Beth
2015 F250 Titan 50 gallon
2016 30' International ProPride, EasyStart, Michelin 16", 400AH LiFePO4, Victron BMV 712, Orion DC/DC converter, BlueSolar MPPT 100/30, Victron 12|1200 inverter, 300W solar mix, Alpine iLX, Polk MM1, Samsung 42, one small air plant
mythbuster88 is offline   Reply With Quote
Old 12-15-2018, 07:03 AM   #6
VTSafari's Avatar
2016 27' Flying Cloud
Monkton , Vermont
Losing the stinky slinky is one thing but when mine came out it managed to rip the storage tube off as well. I replaced it with one that actually has a hinge and a latch. The latch has a hole for a lock but think that might a bit extreme. I just put a small carabiner in it. Problem solved....so far.
Bill
2016 Flying Cloud FB
2014 Ram 3500 4x4 extended cab
VTSafari is offline   Reply With Quote
Old 12-15-2018, 07:03 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
🦆 Tape.
Zip on, zip off, secure.
Repeat if necessary. 😂
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 12-15-2018, 07:05 AM   #8
Kiss 👍
🦆 Tape.
Amanamus
"Tahawus"
Old 12-15-2018, 08:06 AM   #9
There are thousands of these sewer hose tubes in use on SOBs as well as Airstreams without problem. The cap is a bit tricky to get on, at first, but why blame Airstream for something that is clearly a case of 'user error'.
Ray B.
Old 12-15-2018, 09:46 AM   #10
2017 19' International
Tallahassee , Florida
"... why blame Airstream for something that is clearly a case of 'user error'."
Well, it is a common user error, that's for sure.
The cap is hard to get off, hard to get on, and not entirely trustworthy.
I'm looking for a way to make mine actually secure.
Somewhere in the state of Georgia my original sewer hose is decorating a highway right of way, along with the freedom-loving cap.
WhereStream is offline   Reply With Quote
Old 12-15-2018, 10:15 AM   #11
1994 30' Excella
Mississauga , Ontario
I lost a hose first year I had my trailer. The cap does have a lanyard attached so I didn't actually lose the cap. To prevent future loss I put the cap on properly, then drilled a 1/8 inch hole through both the cap and tube so I could put a piece of wire there to keep it closed. Has been perfect for 14 years.
Al
Al and Jean
TAC ON-3
BigAl is online now   Reply With Quote
Old 12-16-2018, 10:02 AM   #12
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Al
Like this!
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 12-16-2018, 10:39 AM   #13
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Just like all the accessories on an AS, the under trailer storage tube is a generic item. If anybody has seen a better generic item (as opposed to a DIY solution) maybe that would be worth talking about. The idea that AS should go out and tool something from scratch - not going to happen. I also very much doubt that the esthetics of a chunk of white PVC are going to make it past the marketing guys ....
Old 12-22-2018, 03:47 PM   #14
To prevent another runaway hose, I trimmed down a piece of inner tube (left over fr one of my bikes) and lashed the cap in place.
Don't have to un-lash. Just lift it off, loosen the cap and pull out the hose.
E-Z to install, and it should keep the cap and hose well behaved.
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 37 02-06-2018 02:53 PM
Disappearing Threads jaco Off Topic Forum 35 12-24-2007 01:28 PM
More Mysterious Disappearing Threads Hit'nMiss Forum Admin, News and Member Account Info 14 06-13-2005 11:43 PM
Disappearing Posts hhuber Forum Admin, News and Member Account Info 5 08-17-2004 02:39 PM
