Old 06-15-2019, 02:44 PM   #1
2017 25' Flying Cloud
the woodlands , Texas
Dinette table won't go down
I have a 2017 25' Flying Cloud. We are trying it out with the dinette table down(to try to find a comfortable seating arrangement). The table is VERY hard to get into the down position. Dear Hubby is busy and I can't get it down. The brackets don't slide out on the wall. What will help? Is this normal? Thanks.
Leslie
Leslieotr is offline   Reply With Quote
Old 06-15-2019, 02:57 PM   #2
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Are you lifting up on the edge of the table (the edge opposite the wall, closest to the leg? That should cause the tabs to slide out of the brackets. Then pull forward to allow the table to swing down.
pcskier is offline   Reply With Quote
Old 06-15-2019, 03:28 PM   #3
Yes, I am pulling up on the edge nearest me after the table leg has been stowed. Left tab almost slides out, right one doesn't budge. Am I just not strong enough? Or is this defective?
Old 06-15-2019, 03:54 PM   #4
pcskier's Avatar
Park City , Utah
All I can suggest is to wiggle the table back and forth (side to side slightly) while lifting carefully, and/or also push on it slightly while lifting, especially on the right side to take tension off that right tab. If not, try gently pulling as you lift up--it really depends on if your tabs are tight on the front or the back side. Sounds like you have a tight fit, which actually is a good thing. Some people have had their tables unhook and crash down on bumpy roads. A tight fit will help prevent that.
Old 06-15-2019, 08:16 PM   #5
Thank you. Dear Hubby is going to help. Hope we can make it work.
Old 06-16-2019, 10:17 AM   #6
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
If you haven't done it before, it will be hard. Once you do it a few times, the opening slit, will open up a little more making the process easier.
I thought I was going to rip the brackets off the wall.
Here are the steps.
1. Fold the leg
2. Lift up the closest part of the table
3. Slightly pull towards you, very slightly
4. Once the brackets are off the mounts, pull a little more towards you
Viola!
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Dinette Table - Up or Down While Traveling? eagletoo On The Road... 47 09-05-2018 09:31 AM
entire dinette (table, seats and cushions) and flip down table furtrader Airstream Classifieds 0 05-25-2017 05:20 PM
Dinette Table (table top and 2 legs) helluva Airstream Classifieds 0 04-25-2016 12:49 PM
credenza, dining table, small table for top of credenza, small table from other side of trailer janeinthemtns Airstream Classifieds 1 09-25-2014 05:24 PM
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
