Old 08-26-2019, 11:08 AM   #1
Llittle54's Avatar
2016 16' Sport
Port Angeles , Washington
Dexter Lift Installed
Lift kit installed yesterday. Mental and physical gymnastics are involved! By the fourth wheel we had it figured out..... There’s a ton of info in the forum on the installation. Here are my lessons learned even after reading every post a few times.
My installation was on a 2016 FC 23 FB
* #10 lift kit needed - sent dexter pic of the axel tag for verification
* Build ramps for safety!! I felt much safer than just jack stands. It took about 15 minutes to throw scrap lumber together.
* Do rear axels first. More access for getting to the front axels once everything is raised after the first axel is lifted. (I wish I had known this ahead of time)
* Unlike dexters instruction but like described in the forum the lifts go in with open face AWAY from the wheels
* Do remove the shocks. One bolt, no big deal and lots more room.
* I didn’t have to remove the propane line. Detached one end during the lift to release any tension. There was enough play that I was able to reattach line after the lift.
* leaving the propane line makes for a very tight fit in getting a socket on the bottom nut, but doable.
* Was able to use regular sized 15/16 wrench with gymnastics. Others have had to use a shorty.
* A big torque bar was invaluable for loosing and tightening.
* Get a variety pack of socket extenders a short and a long 15/16 socket
* In my installation there was no play forward or back. The holes line up tight so wheel alignment did not seem like an issue.
* Have a great and patient helper like I had with my wife!
Llittle54 is offline   Reply With Quote
Old 08-26-2019, 11:43 AM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Kudos to your wife! Many would say they aren't your apprentice.
Thanks for your valuable insights.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 08-26-2019, 11:48 AM   #3
Llittle54's Avatar
2016 16' Sport
She’s the smart one. By helper I mean equal, we helped each other but she doesn’t post!
Dexter Torsion Axle Lift Kit outofcontrol Axles 218 12-23-2022 12:07 PM
Largest tire size w/ Dexter 3" lift kit installed? Airstreamkup Tires 18 05-11-2022 10:24 AM
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 09:23 AM
Dexter Axles INSTALLED... TN-TUNDRA Axles 17 03-29-2008 09:09 PM
