Old 08-31-2012, 07:48 PM   #1
2004 25' Safari
San Francisco , California
Angry Dented Airstream
Today I accidentally scraped the side of my 2004 25 foot Safari. The back right rear side is quite dented. I am traveling East from Calif to Kentucky and may take it up to the factory in Ohio for repairs. Anyone have any advice re costs, time it would take for repairs, where to go, etc? It looks like two panels need to be replaced, and a right side running light.
a.moore is offline   Reply With Quote
Old 08-31-2012, 08:38 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Dents can often be worked out. Creases and wrinkles are permanent. Photos would help. Most Airstream dealerships could do the repair.If you are replacing a panel, I'm not sure, but I would expect to pay a couple of thou per panel.
Old 08-31-2012, 09:18 PM   #3
chromechaser's Avatar
1974 25' Tradewind
kirkland , Washington
Sorry to hear that. I've had quotes from two airstream dealers. They both said to expect to pay 3k per panel label and materials. The panel prices from dealerships are around $1,000.00 but I've seen them as low as $350.00 at inland r.rv. In Cali.
chromechaser is offline   Reply With Quote
Old 08-31-2012, 09:21 PM   #4
dznf0g's Avatar
Oswego , Illinois
I had 2 panels replaced last fall at JC, and it was about $3500.
-Rich-
Old 09-01-2012, 12:30 AM   #5
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I had to have the entire lower panel replaced on my street side a few years ago. That's a flat panel 14' long x 4' high. The only curvature was along the bottom where it was gently pulled in to meet the belly pan. Cost was in the 3500 range. I can't remember because my insurance paid for the entire job. My only expense was my gas to take it to and back home....about a 4 hour one way drive. Do you have insurance? Hope so.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 09-01-2012, 02:23 PM   #6
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Replacing a Panel
The P.O. put a dent in the back right top curved end cap panel. It doesn't leak, so I was OK leaving it as a sign of honest wear. Linda wants it replaced so we are going to take it down to Out of Doors Mart, Colfax. NC, [http://www.odmrv.com/] in a few weeks to have it done. They quoted $1400-1500 labor and materials. I've seen them working on other panels. They've replaced our A/C and generally been extra helpful for all things Airstream.
Name:	PO Dent Pic.jpg
Greg and Linda Heuer
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 09-01-2012, 03:04 PM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
Silver Otter,
That kind of dent can be considerably reduced from the outside. It could be reduced even further from the inside.
I have never replaced a panel but from what I have heard the replacement panel finish will not exactly match the other panels.
Old 09-01-2012, 04:17 PM   #8
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
We have a similar dent, occasioned on our first trip and down to my inexperience. I did pull it out a little but we decided to leave it there as a reminder and, as Greg says, a sign of honest wear. It also makes us unique when in a field of Airstreams!
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 09-01-2012, 09:10 PM   #9
1981 31' Excella II
New Market , Alabama
I would not have that panel replaced unless they are going to buck rivet it back in. That does not look like a bad dent. I expect an experienced dent doctor could pull that out so it is barely noticeable. Structurally it is better than an Olympic riveted replacement.
Perry
Old 09-01-2012, 10:09 PM   #10
1960 24' Tradewind
Riverside , California
I'd have to argue that point, the shear strength of the Olympic is much greater than the softer buck rivet, and by rolling the Olympic in sealer before installation you can get sealer at the back.
Greg
1960 Tradewind
2007 Denali 6.2
2005 ST 1300 ABS
2005 Chevrolet SSR 6.0 LS2
airstreamlosangeles.com
ZoomZoom is offline   Reply With Quote
Old 09-01-2012, 10:38 PM   #11
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I don't think people give credit to Olympic rivets... So here is a personal experience.
While putting my shell back on I had "4" Olympic rivets in the front of the Airstream. It slipped off it front jack stand and those 4 rivets held the frame to the shell while I got the jack stand back under it. The shell was hanging from my Gantry's.. Now I'm guessing the front of the frame weighs well over 400 lbs, and was supported by 4 Olympic rivets..
So when people talk about Olympic rivets not being strong, I believe it is an assumption not a fact. Now are they as strong as a buck rivet? I don't know I would have to put two to the test.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
