Old 11-06-2015, 03:28 PM   #1
2010 23' Flying Cloud
High point , North Carolina
DENT repair???
We bought a used 2010 23' Flying Cloud from dealer. We noticed a 6" roundish dent on the front neat the top (see photo). I guess they didn't want to mess with it cause the dealer called it a "character bump" and said it couldn't be pulled out since it was not on a flat surface and a riveted seam. Blowing smoke or was he telling the truth? Seems like they pull dents out of cars all the time, so why not on an AS???
Gmutt is offline   Reply With Quote
Old 11-06-2015, 03:46 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
From my personal experience, this does not look pullable. The seam line makes it more difficult. As long as the seam does not leak water, I would leave it alone. Auto paintless dent repair is accomplished by usually pushing from the back side. The interior wall prevents you from doing this on an Airstream. If the dent was not on the seam you might try pulling with a " Dent King" that uses hot melt adhesive to bond a puller pad to the aluminum.
Old 11-06-2015, 04:51 PM   #3
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Klutch Pneumatic Dent Puller | Auto Body Tools| Northern Tool + Equipment
I have one of these dent pullers and it would easily pull out that dent. Even over a seam it just needs to be duct taped down to hold the seal.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 11-06-2015, 05:57 PM   #4
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
I pulled a lot of dents out of mine with the dent king. It could sit on both sides of the seam, and it holds pretty well.
Silverflames is offline   Reply With Quote
Dent repair options automatik Ribs, Skins & Rivets 11 11-03-2006 03:23 PM
Dent repair? gflatt Exterior Restoration Forum 2 07-06-2006 09:53 PM
dent repair in oregon nevisstudio Ribs, Skins & Rivets 6 08-25-2005 11:40 AM
Dent Repair AccessMaster Ribs, Skins & Rivets 4 08-26-2003 05:35 PM
Dent Repair Jim W Ribs, Skins & Rivets 3 05-07-2002 11:43 AM
