Old 08-07-2016, 08:13 AM   #1
2017 27' International
Canfield , Ohio
Dent formed in side
I woke up this morning and looked outside and there is a dent in the side of my trailer. Now we just bought this trailer a week ago and stayed in it last night in our driveway. Dent wasn't there when we went to bed. How could it be there now!
I am a bit upset. Is this normal? Last night was the first cool night we've had here in a long time. It went down to 56 degrees. this morning the sun is hitting the trailer on that side. Could this be an issue with how it was put together? I will post some pictures later, but the dent is about a foot around.
Any ideas?
2017 Airstream International Signature 27FB Twin
turk123 is offline   Reply With Quote
Old 08-07-2016, 08:20 AM   #2
1986 31' Sovereign
Miami , Florida
Oil canning. Aluminum changes dimensions with varying temperature. Should look normal soon as it warms up.
Old (usually dirty) Nissan Titan
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 08-07-2016, 08:46 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Normal expansion of the shell panels, the "dent" will most probably go away when the sun moves away and the shell cools tonight. The underbody panels act the same way, and sometimes may be heard as thunder just walking through the Airstream.
Doug and Cheryl
Old 08-07-2016, 09:06 AM   #4
ArtisanAir's Avatar
1967 28' Ambassador
1964 19' Globetrotter
1960 24' Tradewind
Edgewood , Kentucky
the stabilizing Jack's can cause this issue also. The longer the trailer the more susceptible it is to this issue. If the heat doesn't correct it try putting it back on its tires and see if that fixed it
Artisan Airstreams
Custom restorations and renovations
www.artisanairstreams.com
Keeping the Art on the road, one project at a time
ArtisanAir is offline   Reply With Quote
Old 08-07-2016, 09:11 AM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have a dent (previous owner) on the right rear side. It comes and goes as the seasons change. Just another of those little Airstream quirks.
MICHAEL
Old 08-07-2016, 11:44 AM   #6
Canfield , Ohio
Name:	ImageUploadedByAirstream Forums1470588186.381202.jpg
Here is the first one. A second one developed as I watched
Old 08-07-2016, 11:44 AM   #7
Canfield , Ohio
Name:	ImageUploadedByAirstream Forums1470588274.361858.jpg
Second one under vent
Old 08-07-2016, 01:17 PM   #8
1973 31' Sovereign
Middletown , California
Try holding an ice cube in the middle of the dent and see what it does! My guess it will suck right back to normal but reappear when sun first hits that panel. I don't know if you can stop this from happening without going through a lot of work to permanently shrink that panel a bit. Probably not worth the effort.
ijustlee is offline   Reply With Quote
Old 08-07-2016, 01:24 PM   #9
dkottum's Avatar
Best not to mess with it, may cause permanent crease. The panel metal has to expand in the sun's heat, it's the nature of things.
Doug and Cheryl
Old 08-07-2016, 01:29 PM   #10
Safari Streamer's Avatar
2015 28' Flying Cloud
Ladson , South Carolina
It's brand new, I'd call the factory!
Kathy Narowski
#2555
SC Coastal Unit
TAC-SC5
Safari Streamer is offline   Reply With Quote
Old 08-07-2016, 02:46 PM   #11
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I agree. I do get some very mild panel deformation with sun heat but nothing like as much as that. I would not be happy with that, especially on a new trailer.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 08-07-2016, 02:52 PM   #12
2002 31' Classic
Houston , Texas
Stabilizers
Just in passing, and I do NOT have a full grasp of your understanding of stabilizing jacks, the stabilizing jacks are not to be used to lift the tires off the ground. I realize that's not exactly what you said, but I take "putting it back on its tires" means they were off the ground.
You may know this (some don't), but just in case, the trailer should be levelled in some fashion (and there are several ways to do this, of course), and the stabilizing pads should be extended to put maybe a 1/2 inch or so lift to the trailer at each of the pads to keep the trailer from rocking when someone is walking inside.
I wouldn't be at all surprised if wrinkles (maybe permanent ones) were to develop by using the stabilizing jacks as lifts to take the tires off the ground. There are a couple of other bad results to that practice, as well.....
Did I miss your point?
Kent
Houston
Kent M is offline   Reply With Quote
Old 08-07-2016, 03:18 PM   #13
Canfield , Ohio
Kent
Houston
Nothing left the ground. I was told how to use the stabilizers and just snugged the ground to stop rocking.
As the sun grew higher in the sky, the dents dissappeared. I guess i will have to keep as eye on it. I dont really want them to be a permanent thing.
Old 08-07-2016, 06:08 PM   #14
2002 31' Classic
Houston , Texas
Regarding Stabilizers and "dents"
My comment was two fold, but mostly to confirm that no one would use the stabilizers as trailer jacks.
One less-than-serious question I do have of you is "Why keep an eye on them?" If they do it again, you have excellent reason to believe they won't be permanent, just as others above related. It's an interesting phenomenon, to be sure, and an excellent conversation starter.....
Kent
Houston
Street-Side Dent Bauxter Ribs, Skins & Rivets 28 03-01-2011 03:38 PM
Side to Side Leveling gorrissen Jacks, Stabilizers, Lifting and Leveling 26 08-02-2009 08:50 PM
Side to side leveling: can I use the stabilizer jacks? iAirstream Jacks, Stabilizers, Lifting and Leveling 4 08-17-2007 08:33 PM
Side-to-Side Flooring Replacement in Classic MH Eddy Repairing/Replacing Floor &/or Frame 12 11-03-2006 02:08 PM
Weight Distribution, side to side JimC Towing, Tow Vehicles & Hitches 8 08-13-2003 04:19 PM
