Old 09-21-2015, 08:06 PM   #15
2013 25' FB Flying Cloud
Fort Lee , Virginia
Thanks for all of the input, folks. I'll follow-up with AS regarding the actual rivets and the notion of "bad lot of rivets". Worth that at least.
COLGeek is offline   Reply With Quote
Old 09-21-2015, 09:39 PM   #16
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Airstream has a warning in the Owners Manual about selecting heavy duty springs in a tow vehicle. Repair shop owners in the forum have warned about excessive pressure in the tires and too stiff weight distribution bars, as well as out of balance running gear. And then there are the roadways we travel on and the speed we travel at.
It accumulates. The more the Airstream gets knocked around during towing, the more likely rivets will pop, hinge screws loosen, things break and fall off.
Doug and Cheryl
Old 09-30-2015, 12:50 PM   #17
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
X2 on overly hard tires!
A few days ago I serviced (bal and rotate) all 6 tires. Later that day everything inside was tossed about, drawers open, stuff a mess. In 160000 miles towing I have never experienced this mess! I decided to check the freshly serviced tires.... As I suspected, the tire professionals inflated my 6 tires to 90 psi.... The sidewall max! I lowered pressured to my normal 66 psi, and back to interior bliss, nothing, not anything out of place after the next days travel.
I suspect many rivet popping is from hard tires and or out of balance tires!
Old 09-30-2015, 02:10 PM   #18
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Sheared rivets are a sign of a rough ride.
Centramatics on the running gear, tires over inflated, and maybe a softer hitch will correct the problem, and save you from cracked frames and broken skins.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
Contacting CATCON re: defective unit mhilley Electrical - Systems, Generators, Batteries & Solar 21 04-07-2014 08:48 AM
Cutter, Defective Window Seals paulnmargie Windows & Screens 1 01-11-2011 10:05 PM
Defective Odometer Byers Land Yacht/Legacy Motorhomes 5 03-29-2010 11:57 AM
defective knob/stem imagine LP Gas, Piping, Tanks & Regulators 5 03-28-2005 03:51 PM
