Old 07-30-2017, 03:56 PM   #1
2012 22' FB Sport
Seattle , Washington
Dealer installed lift kit?
Do any Airstream Dealers install trailer lift kits? The dealer in my area doesn't.
ChrisnPatty is offline   Reply With Quote
Old 09-28-2017, 09:02 AM   #2
2012 30' Flying Cloud
Morongo Valley , California
I had the "Dexter Axle" lift kit installed at the AS dealer in Tucson, AZ. I supplied the lift kit which I ordered online. This makes boondocking and our driveway approach much less stressful. Can't tell a difference in towing or fuel mileage. I would go ahead and get the kit then when your traveling you can call dealers in your area. It's not rocket science. If you have a good mechanic you trust they could do it. Just make sure you put the jack and jack stands exactly where Airstream recommends. Go to search for video of install.
Alan 117 is offline   Reply With Quote
Old 09-28-2017, 09:28 AM   #3
2018 25' International
East Northport , New York
I was told no by Colonial Airstream. Considering doing it myself over the winter. I have to hit my driveway just right in order not to drag the rear. Dragging a makeshift ramp down to the bottom of the driveway is getting old.
James
Biker is offline   Reply With Quote
Largest tire size w/ Dexter 3" lift kit installed? Airstreamkup Tires 13 04-24-2017 10:25 AM
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 10:23 AM
Should i lift the shell or not lift the shell.. prettybrent Repairing/Replacing Floor &/or Frame 19 09-04-2016 11:13 AM
1997, 34ft Classic: To Lift, or Not To Lift (its shell) mattler General Repair Forum 4 10-16-2015 11:40 PM
Air 'Bags' - too lift or not to lift JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 04-09-2013 11:09 AM
