Old 09-19-2016, 03:30 PM   #1
1993 34' Limited
Angleton , Texas
Damaged subfloor
How do I repair sections of water damaged subfloor?
itc_purpose is offline   Reply With Quote
Old 09-19-2016, 04:25 PM   #2
1979 23' Safari
Wayland , New York
Depends on where the damage is, how big, and how bad.
Photos will help gauge the work required.
There are lots of posts about floor replacement. Google airstream floor repair replacement, or look at some of the full monte threads.
Can be simple cut out old piece, splice in new, or as severe as removing the shell to do it.
Old 09-19-2016, 04:27 PM   #3
FLMarine's Avatar
2009 27' FB International
_ , Florida
Can you give us a little more info? What year and model airstream, where is it damaged, extent of it, what are you skills? I repaired my floor and can give you some advice when we get more info.
FLMarine is offline   Reply With Quote
Old 09-21-2016, 06:45 PM   #4
Kemblkr's Avatar
2003 22' International
South Bend , Indiana
Need more data and pictures and we can help
Kemblkr is offline   Reply With Quote
Old 09-21-2016, 07:27 PM   #5
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Most solutions involve sistering new wood with the addition of cleats to bridge when necessary.
Landing half on a frame is almost always done but a cleat that is glued and screwed can do a lot too.
Digging out under the wall allows the new part to insert there to support the wall. The new part would need to be slotted to allow it to slide in around the bolts.
sgschwend is offline   Reply With Quote
Old 09-27-2016, 02:38 PM   #6
1993 34' Limited
Angleton , Texas
Subfloor damage
Here are pictures of damage
Old 09-27-2016, 05:01 PM   #7
Kemblkr's Avatar
What year ?
Old 09-27-2016, 09:53 PM   #8
1979 23' Safari
Wayland , New York
Wow! That looks nasty! It looks like you should be able to do some sistering though. You'll have to remove the stuff on top of the spot, plus a few inches to get to some good wood. Then you cut a patch to match the shape of the hole. Or backwards for ease, see below. On the old floor around the perimeter, cut some strips of wood that will project a few inches under the old floor and stick out a few inches for the new floor to sit on. Use some liquid nails to glue and screw the strips up from the bottom around the hole. Once that sets a little you can put some liquid nails on the piece that projects from under the old floor for the new floor to sit on, then screw the new flor down.
A easy way to get the patch and hole to match is to get a good idea of how the patch will be and then make it first. Then trace it onto the old floor and cut that shape out.
Your tanks are going to be under there, so watch the depth of your cut. A circular saw with the depth set just a little shy of going all the way through, or oscillating tool would work well in this case.
Old 09-27-2016, 10:26 PM   #9
1993 34' Limited
Angleton , Texas
This is a 1993 34ft classic limited
Replacing flood damaged subfloor gwidman Repairing/Replacing Floor &/or Frame 10 08-15-2006 09:04 PM
1991 34' Floor water damaged in rear. potatoes Repairing/Replacing Floor &/or Frame 11 06-03-2005 03:45 PM
Break Away Wire Damaged kposey Brakes & Brake Controllers 5 11-11-2004 07:20 PM
1985 Sovereign Damaged in Storm - HELP! Kettyscott Windows & Screens 7 10-06-2004 11:59 AM
Hail Damaged Excella 35...... longhauler 1987 - 1989 Excella 17 07-28-2003 08:38 AM
