Old 08-21-2017, 06:18 PM   #1
Frank&Mike's Avatar
2016 27' Flying Cloud
Georgetown , Texas
Curved Cabinet Door Below the Sink - Fell Off
Have any of you experienced the screws stripping out of the side where the curved cabinet door (below the kitchen sink) is installed ... and then the door falling off? If yes, how was it repaired? I don't see where the hardware will accommodate any larger diameter screw than what was used. Guess I'll be taking it in for service to ensure it's repaired properly before the warranty expires.
Name:	Cabinet Falls Off.jpg
ID:	292912   Click image for larger version
Name:	Cabinet Screws Stripped Out.jpg
Frank&Mike is offline   Reply With Quote
Old 08-21-2017, 06:55 PM   #2
Piggy Bank's Avatar
2017 25' Flying Cloud
2015 22' FB Sport
Kansas City , Missouri
If you need to do a fix on the road, get some gorilla glue and a wooden match or toothpicks. Remove the screws, dry fit the match (wood end of course) or toothpick in the hole. Wet with glue, insert, let dry, and then trim away the standing portion. Now you should have some surface area for the screws to screw into to re-attach.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 08-21-2017, 09:27 PM   #3
2007 22' International CCD
I use bamboo skewers or bamboo toothpicks because the fibers seem to be stringer. Ordinary matches are made of very soft wood...
KE4GNK/AE
Old 08-21-2017, 10:30 PM   #4
Docinabox's Avatar
2016 23' Flying Cloud
Goodyear , Arizona
Just fixed my kitchen sink door a few days ago. My right top hinge screw fixation completely failed. Airstream never placed the center screw in the hinge base. I went with larger screws, #10, in the top and bottom hole and a smaller #8'wood screw in the center hole. I drilled out the existing holes so they could accept the #10 screws. Because the sink is in the way, I removed this to gain clear access to the upper hinge.Very solid now.
ID:	292924   Click image for larger version
Docinabox is offline   Reply With Quote
Old 08-22-2017, 12:25 PM   #5
Rgentum's Avatar
Woodinville , Washington
Match stubs plus glue has worked for me, at least so far.
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2015 Ram 2500 Laramie 4x4 Diesel
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 08-22-2017, 01:55 PM   #6
Mollysdad's Avatar
How did it fall off? While driving or someone walked into it while open? By your picture, it looks like two screws are good, but the third ripped out and took the door with it.
I see there are drawers to the left of the sink, can you remove the drawers and get a nut on a machine screw to through bolt it?
"Anything worth doing is worth overdoing." -- Mick Jagger and me.
Sigh.
Mollysdad is online now   Reply With Quote
Old 08-22-2017, 07:50 PM   #7
Frank&Mike's Avatar
Georgetown , Texas
Louisiana Highways - A Disaster
Thank you for the suggestions and most of all thank you for showing the "repair."
Originally Posted by Mollysdad View Post
How did it fall off? While driving or someone walked into it while open? Sigh.
It fell off as a result of IH10 in Louisiana beating the heck out the Airstream ....... anyone that has traveled IH10 in Louisiana knows what I'm talking about when I say "the washboard between Lafayette and the Atchafalaya Basin Bridge will destroy your Airstream and it's one of the most dangerous stretches of road because of its pathetic condition!" Avoid it at all cost and no matter how many hours it adds to your trip.
Old 08-22-2017, 09:56 PM   #8
2010 25' FB Flying Cloud
Davenport , Iowa
I m not having trouble with the screws, it is the hinge it s self. They are loose and the doors keep opening and we have to tie them shut. I have tried the adjusting screws, but doesn't t work, suggestions?
Mike
Airtandem is offline   Reply With Quote
Old 08-23-2017, 06:42 PM   #9
Frank&Mike's Avatar
Georgetown , Texas
Mike
Hmmmm...we haven't had that problem. Not sure what to suggest with that. Hopefully others will offer some ideas.
My battery compartment door fell off DougZ Exterior Storage Compartments & Access Doors 0 06-05-2011 06:05 PM
Door lever fell off GreginNH Doors & Locks 3 04-28-2007 04:57 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
Dometic door fell off rochar3 Refrigerators 1 07-24-2004 12:17 PM
