Old 06-23-2018, 05:18 PM   #1
art
curtains cleaning
2004 classic has a little mold on back of curtain san you just put them in machine any advise
art is offline   Reply With Quote
Old 06-23-2018, 05:41 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Per Airstream ---
Dealer Awareness Bulletin
Cleaning fabrics
Curtains
Airstream curtains can be successfully cleaned, within reason, by following the instructions below.
Safari and International Curtains.
Curtains for the Safari and International trailers are currently manufactured by Dana Mills Inc.The fabric is comprised of 87% polyester and 13% cotton. Since the fabric is made from cotton it will shrink. Danna Mills recommends the fabric is Dry-cleaned however; it can be washed in cold water using a perfume free soap and non chorine bleach if needed. Air-dry the curtains after the washing is completed.
Classic Curtains.
Curtains for the Classic trailers are currently manufactured by Milliken Inc. and distributed by Crestmont fabrics. The fabric is comprised of 100% polyester. Crestmont recommends the fabric is washed in water no warmer than 160 degrees using a perfume free soap and non chorine bleach if needed. Do not use any fabric softener as this will damage the material. The curtains can either be Air-dried or tumbled dried on medium heat. In the event ironing is desired use the low setting.
Ultra Leather
Airstream uses Ultra leather fabric style 303 on the lounge and dinette seats in certain model Travel Trailers, Interstate Vans and previously on the Class A motorized products.
It is a polyurethane fabric with a rayon reinforced backcloth that has very high wet and dry capabilities- which translates into a stronger yarn and fabric.
Care Instructions
Remove the stain immediately
Spot clean with mild soap and water
Air dry or dry quickly with warm setting of a hair dryer
For stubborn stains use a MILD solvent
For tougher stains use Fantastic or 409 brand cleaner
Disinfect with a 5:1 bleach solution
Machine Washable—Gentle wash cycle.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 06-23-2018, 09:14 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
I washed some of mine. I folded them and put them in a large utility sink filled with knock-off Woolite. I agitated by hand a bit and rinsed. I hung them to dry. They turned out nice.
CRH is offline   Reply With Quote
Old 06-23-2018, 10:20 PM   #4
StreamNTyme's Avatar
2007 25' Safari FB SE
Carolina Low Country , South Carolina
Images: 27
I have washed them in the washing machine on gentle, put them in the dryer just to get them slightly dry, immediately pressed and pleated them with my hands and hung them in the trailer damp. Turned out beautiful, crisp and really clean.
StreamNTyme
StreamNTyme is offline   Reply With Quote
Old 06-24-2018, 11:06 AM   #5
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
We store our 25FB Classic in the Phoenix area. At the start of each traveling season I remove the curtains let stand over night in cold water with Oxi Clean in the water then wash in washer on delicate with a small amount of bleach then dry by hanging. I have been doing this for the past five years No problems and they are white
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 06-24-2018, 11:15 AM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Wash, gentle cycle.. hang damp.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-02-2018, 07:48 PM   #7
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Help. Just noticed that our 2014 International curtains have a mold stain on them. I have tried all the suggestions mentioned except I have only used cold water with the oxyclean. I have soaked them and I have made a paste and gently tried to scrub them and also tried a combo of borax and oxyclean.
Nothing seems to help. I now have very clean curtains with mold stain on the bottom edge. Some parts more than others.
Any ideas out there.
gandttimes is offline   Reply With Quote
Old 08-03-2018, 05:52 PM   #8
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Thanks. Figured out how and it worked fine.
"air curtains" customized handmade curtains for your airstream any model any year ChrisseasCC Airstream Classifieds 0 10-20-2013 05:25 PM
Resource for Curtains and Shower Curtains jmagers General Interior Topics 0 07-15-2013 06:00 PM
Cleaning Curtains Airhog1 Commercial Listings 8 06-02-2007 09:00 PM
Removing Curtains for cleaning? George Jr. Upholstery, Blinds, Walls & Interior Finishes 6 03-21-2004 03:11 PM
