Old 02-06-2010, 04:55 PM   #1
2008 16' Bambi
brockville , Ontario
cupboard cracks and freezing fridge.
Has anyone any experience with hairline cracks on moulded overhead cupboards at bottom round,or, with a Dometic fridge with no temperature adjustment running too cold [the temperature sensor has been replaced to no avail]. Our unit is a '08 16, bambi.
margjo is offline   Reply With Quote
Old 02-06-2010, 05:26 PM   #2
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Andy say something!
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 02-06-2010, 05:53 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Is the problem on both gas and electric?
The placement of the sensor on the fins can effect the sensor.
Check the location of your against another ref.
Make sure the control wires are connected to the board and they are tight.
How about a picture of the crack in question? I have repaired cracks in the interior end caps but want to see what you have.
2004 Excursion 4x4
Old 03-12-2010, 06:34 PM   #4
Just saw this post.
Hairline cracks, on a new coach suggests bad vibration. Find the cause.
Reefer in a runaway mode??
Possibly, back to vibration, that fractured the thermocouple, which would let the reefer get as cold as it can, without any control.
Old 03-13-2010, 10:54 AM   #5
2010 27' FB Classic
N/A , Texas
Check and see if that fridge has a recall notice. If I remember there was a problem at Dometic a couple of years ago but I don't remember what the recall was about.
Kitchen cupboard wire storage racks hamradio 2006 Safari SE 8 11-17-2010 06:53 PM
Freezing in CT.... NOT! bobfowler All Argosy Trailers 14 12-03-2008 08:44 PM
Floor Cracks, Door Cracks & more Cracks JMR Axles 15 06-29-2005 01:42 PM
Help need one cupboard door altastars Cabinets, Counter Tops & Furnishings 1 09-07-2003 05:01 PM
Repairing cracks in fridge plastic? Charcigar Refrigerators 2 05-01-2002 07:44 AM
