Old 12-15-2015, 11:44 AM   #1
Creaking floor
My wife and I bought a new 2016 30' International Signature trailer. It's had some problems that have been taken care of. There is still one left. We have a terrible creaking problem in the bedroom floor. As far as I know I have two options. We can try to live with it or let the dealer fix it under warranty. Aside from the long haul to get it there my biggest problem with that option is that they have to cut open the under belly, put some shims in, & then patch it up. That seems like a very invasive fix. So I was wondering if anyone knew of another way to fix it. Thanks in advance.
loberg is offline   Reply With Quote
Old 12-15-2015, 12:54 PM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Since it's brand new you have a two year warranty. You can probably wait to see what happens. Maybe the creak will dissipate or you can just plan to make a trip to the dealer or JC at a later date.
More than likely due to the length of your trailer there are multiple sections used for the subfloor so its probably a joint and due to temperature and humidity it may creak more at sometimes.
Does it creak just as much when the stabilizers are down? Is the trailer on uneven ground when you notice the creaking?
If the repair can be done from underneath that would be a better solution then tearing up the vinyl floor. The underbelly can be removed and riveted back.
Kelvin
Old 12-15-2015, 01:22 PM   #3
It doesn't matter if it's on even ground or if the stabilizers are up or down. It's worse on one side of the bed than the other. I think I'll probably bite the bullet and take it to the dealer. They have to keep it for a few days. So it's 3 hours there, 3 back then I have to do it over again when they're finished with it.
Old 12-15-2015, 02:17 PM   #4
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
For what it's worth, I would wait. You are likely to find additional issues that warrant attention. They can all be addressed at once.
Also, depending on where you are and where you are traveling, you may want the repairs done at Jackson Center or a reputable dealer such as Colonial.
That said, the underbelly removal and shimming is not that difficult for a decent dealer.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 12-15-2015, 02:37 PM   #5
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
And it's the belly pan- it's not like they are opening the exterior skin.
2012 Dodge Durango Hemi/AWD
Old 12-15-2015, 02:42 PM   #6
Ok. Thanks. Point well taken.
Old 12-15-2015, 05:20 PM   #7
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
This is common on Airstreams, or at least not uncommon. It seems to come and go with weather and humidity changes, and with how the trailer is positioned. We took ours in for warranty work, and the temporary fix was working with screw tension in areas where something was attached, including the vinyl trim around the edges. We considered taking it to the mothership for a more permanent fix, but decided to just live with it. I'll get the screwdriver out and work things over if it gets on my nerves.
It sucks to spend that much money on an Airstream, then have something like this be a nagging issue, but it's not a fatal disease.
Old 12-15-2015, 06:20 PM   #8
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Dropping the belly pan to access the underside of your floor to address this issue is not a big deal for an experienced Airstream mechanic. I would not let the dealer simply "cut" out portions of the belly pan to access the affected area. I agree with others here that you might want to wait a year or so to see if the problem goes away or expands to other areas of the floor. Might as well do the surgery only one time.
Bob Martel
WBCCI# 5766
Old 12-15-2015, 09:53 PM   #9
Pat Cassity's Avatar
2015 27' FB International
Montgomery , Texas
Loberg, had exactly the same problem on my 2015 27' Serenity. I was told to loosen or remove the screws in the trim on the floor under the window. When I did so, the floor noise disappeared. I was able to screw a couple back in at a different angle but one had to be left out to keep the noise from returning. Hope this helps.
Retirement! Every day's a Saturday and Monday's no longer exist!
Pat Cassity is offline   Reply With Quote
Old 12-16-2015, 03:33 AM   #10
Thanks Pat, I'll try the trim screws idea. I will be extremely happy if that turns out to be the fix. If it doesn't I'll probably take the suggestions of waiting a while. I'm not living in the trailer full time so I guess I can live with the noise the times that I use it, for now. If the problem persists I will have it taken care of before the warranty expires.
Old 12-16-2015, 03:40 AM   #11
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The creaking is from two pieces of the plywood floor being positioned slightly too close together, and rubbing against each other when you step on the joint. It is most common at the corner of the bedroom floor near the base of the bed.
I have successfully stopped the creaking by removing that grey strip that is screwed to the edge of the floor, gently pulling up the edge of the flooring, and liberally spraying silicone dry lube on the floor where the two pieces of plywood meet and touch.
Old 12-16-2015, 09:23 AM   #12
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Scott is 100% correct about this. Start a punch list and when it gets long enough, take your trailer in for warranty work. If your trailer is anything like ours, you'll definitely be going back more than once for warranty work for a bunch of minor issues (e.g. each one is annoying, but none of them stop you from camping). Might as well make each trip count for as much as possible!
Rocinante is our 2014 International Signature 27FB
Old 12-16-2015, 09:36 AM   #13
mefly2's Avatar
2015 25' FB Eddie Bauer
Our squeaks were coming from the trim around the edge of the floor ... several drops of Armorall between the aluminum trim and the side wall and voila ... squeaks gone.
Old 12-16-2015, 10:13 AM   #14
Well Preserved
1993 21' Sovereign
FWIW, there is a squeak, and a creak. The creak is from the movement of the wood against another piece of wood, and the squeak is usually from the vinyl trim piece rubbing on the aluminum wall.
Crazy Creaking in Floor LOGRIDER Repairing/Replacing Floor &/or Frame 20 02-23-2015 10:24 PM
Newly creaking floor in our new trailer... Rocinante General Repair Forum 5 04-17-2014 12:25 AM
Creaking floors wmarsha 1998 Excella 1000 3 01-16-2013 07:52 PM
What to do - Above floor Tank or Below floor tank ??? fatwgn Sinks, Showers & Toilets 8 09-06-2009 02:50 PM
Creaking Floor SilverCabin General Interior Topics 2 05-22-2009 10:04 AM
