Old 06-03-2014, 12:51 PM   #1
Pat Cassity's Avatar
2015 27' FB International
Montgomery , Texas
Cracked Window Guard
While preparing for a trip this week, I noticed that the front right window guard has a crack, probably from a rock strike. In fact, it can't been seen from the outside. It is only visible from the inside when the curtains are open. Is this something that needs dealer attention or should a automotive glass repair shop be able to repair?
Retirement! Every day's a Saturday and Monday's no longer exist!
Pat Cassity is offline   Reply With Quote
Old 06-03-2014, 01:17 PM   #2
1976 31' Sovereign
Oswego , Illinois
they are plastic & you can stop drill with 1/8 drill bit at end of crack should not run any more. I would do this & forget about it as mine has 2 cracks. Why pay dealer lots of money when this is a simple fix
Old 06-03-2014, 01:47 PM   #3
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Both sides of ours have cracks. I removed both, cleaned them well, laid them on a work table front side down, and used an insulin syringe with a very small needle to apply acetone into the cracks. Acetone can be used to bond many plastics, however, it will not soften the plastic syringe Use wooden blocks to support the curved panels after application to keep the cracks closed while the acetone bonds the plastic. It only takes a few minutes. Care must be taken not to get the acetone outside the cracks as it will dull the finish on the plastic.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
'89 excella - Plastic window trim cracked.. epoxy to repair? mikeandnora General Interior Topics 6 05-31-2012 07:18 PM
Has anyone here actually cracked or broke a front wrap around window?? VonLuck All Argosy Trailers 30 04-01-2012 09:31 AM
Cracked side rock guard Argy 78 Rock Guards, Segment & Window Protectors 6 03-22-2012 08:59 PM
'66 Safari - step and window guard parts? Gordon 1966 - 1968 Safari 1 04-20-2002 11:16 AM
