Old 04-13-2014, 12:56 PM   #1
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Cracked tambour housing.
Anyone had this problem? I wonder if there is something other than fibreglass cloth to patch it. Thanks, M
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 04-13-2014, 01:25 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
If you have good access to the back of the crack you might try putting a good "tooth" on the plastic, (tooth= aggressive sanding or grinding with a coarse medium) and using an epoxy glue in conjunction with fiberglass mat.
I imagine that the back of that plastic is so smooth and slick that getting glue to stick without a good sanding is highly doubtful. A failed glue joint sucks to no end.
If you can't get to the back, I would consider learning to ignore the crack. It will be difficult to achieve a solid and good looking repair on that piece without extensive refinishing of the entire piece, and even then, preserving and/or recreating the texture will be next to impossible.
Old 04-13-2014, 01:33 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Would it make me a bad Airstreamer if I didn't know for sure what a tambour is?
Lol, I imagine it is the interior plastic thing that fits under the end cap?
Old 04-13-2014, 01:50 PM   #4
1974 Argosy 20
Kooskia , Idaho
Tambour is the cloth backed material used in the rolling cabinet doors of the 70's trailers. Yours should be loaded with it. Bad Airstreamer, bad, bad.
To Mike: At minimum you should drill a 1/8" hole at the very lower end of the crack to relieve the stress and keep it from growing longer. It is an old, and very successful trick to stop cracks from continuing on their merry way. Be sure you get the end of the crack for your hole.
Old 04-13-2014, 02:13 PM   #5
Mike Leary's Avatar
Images: 11
Here's a tambour door: Thanks to idroba for the drilling sugestion. WD-40 works great to keep the sliders from sticking.
ID:	209595   Click image for larger version
Old 04-13-2014, 03:29 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
My trailer DID have several similar doors, none now though...
Tail light housing on '65 Overlander 65 overlander Lights - Interior & Exterior 5 01-20-2013 05:28 PM
I am looking for a wheel well housing aprimosch Wheel Wells 3 12-25-2008 09:25 AM
Taillight Housing slow-canoe Lights - Interior & Exterior 3 06-26-2007 05:13 PM
I need a reverse light housing!!! gretchen Lights - Interior & Exterior 1 05-21-2007 08:08 PM
Seeking Replacement Stoplight Lamp Housing AirConditioner Electrical - Systems, Generators, Batteries & Solar 0 02-14-2005 05:46 PM
