Old 02-24-2009, 06:30 PM   #1
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Cost of Repair
My 2008 Safari SE FB has a small crease in the streetside of the trailer—it's in the lower panel just below and a little to the rear of the escape window. I know who did it and need to know what my damage is in cash.
I am told the only way to repair it is to replace the entire panel. This is quite a job because there are many things that require holes be cut in this very long panel: furnace, all the water things, etc. I am told it is a 28 hour job. I don't know what it costs and need to find that out, since I haven't been able to get an estimate.
Does anyone know the cost of parts (aluminum, rivets, whatever), materials (sealants, etc.) and have any idea of whether the labor is really 28 hours?
Gene
Old 02-24-2009, 06:35 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Sorry to hear that Gene. There are two methods to repair. One is panel overlay, the other is panel replacement.
Depending on how large a sheet the panel is, it could be pricey. Sounds like you have the lower length segment being replaced.
If you can take pics and contact either of these two folks, they can tell you what to expect in terms of price. The factory does some of the best work I've seen. There is a place in Texas as well that does great work. At any rate, here is the info:
Rick March
rmarch@airstream.com
1-937-596-6111 Ext. 7406
Chris Burch
cburch@airstream.com
1-937-596-6111 Ext. 7413
There was a forum member that came into contact with a guard rail and the guard rail won. The whole lower section of the curbside on his 25 SS was meat. Door damaged, water heater, wheel well. When the factory service center was done you'd have been hard pressed to find any sign that work had been done.
There are maybe 3-4 places in the US I would trust to do a repair like this FWIW.
Old 02-24-2009, 08:36 PM   #3
gail's Avatar
2017 16' Sport
Malibu , California
repairs are expensive! We now try to do as much as possible ourselves.
gail is offline   Reply With Quote
Old 02-24-2009, 08:44 PM   #4
Gene
The labor hours are high.
Where did you get that quote?
A list of materials would be much easier to prepare, if you posted a couple of photo's of the damaged side.
Old 02-25-2009, 11:51 AM   #5
Master of Universe
Gene's Avatar
I have been unsuccessful getting the costs from Airstream, so I decided to ask here. The damage is not as noticeable as you might think, but once you see it, then it stands out. It's not a dent, but has a sort of V at the bottom; it's only about 6" long. There's no other damage to the panel. I doubt it can be easily knocked out from the back. I've PM'd Andy with the particulars. This is all I can really say in public.
Gene
Old 02-25-2009, 12:10 PM   #6
Gene
Gene.
I received your PM, but no photo's.
I must have a photo of the complete side of the trailer and a closeup of the damage, like 3 feet away or so.
Then I can help you.
In the meantime, you should report the loss to your insurance company, along with the circumstances.
It's their job to subtogate against the dealer. They have far more pressure to exert than you do.
Old 02-25-2009, 01:50 PM   #7
Master of Universe
Gene's Avatar
Photos at last
I have had trouble getting the upload to work, but here's my 3rd attempt of the crease and the only photo I could find of that side of the trailer. I think the camera was crooked when I took the photo because we wouldn't have had the trailer at that angle.
Gene
ID:	76002   Click image for larger version
Old 02-25-2009, 01:56 PM   #8
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
hhmmm, the tree's look vertical. sorry just funnin you. Adios, John
Diesel1 is offline   Reply With Quote
Old 02-25-2009, 02:33 PM   #9
Gene
Gene.
Airstream is reluctant to quote prices for material and labor, unless they are going to do the work. If they do quote, they then are placing themselves in competition with dealers, that contractually, they must not do.
You cannot push, or pound out that crease, since the metal is stretched.
You could, get a small louver and place it over that area, and no one would know the difference.
The labor hours, all inclusive is 16. The labor rate, of course depends on where you take the trailer.
Total materials, including the 33" X 201" X .040 inch thick aluminum sheet, along with the Olympic rivets and sealers, costs about $600.00, or so.
Again, the material costs depend on who is doing the work. Some charge a little more and some may charge less. Then freight could also be added, if the dealer did not get month stock orders from Airstream.
The 28 hours is far more than what would be necessary for a 34 foot trailer, let alone for your 25 foot. If someone wishes to place a challenge, my only defense would be that I wrote the crash book, for the old insurance division of Airstream, back in 1970.
If you feel that you have a legitimate problem with the dealer, posting their name, or city for that matter, would be doing a service to your fellow Airstream owners.
One problem for sure, is that their estimate is way, way out of line.
Hope this helps you, without raising your blood pressure.
Old 02-25-2009, 02:50 PM   #10
Master of Universe
Gene's Avatar
Thanks Andy. That gives me something to work with.
Does anyone else have any experience with this type of repair?
Gene
Old 02-25-2009, 03:20 PM   #11
repair cost
CORRECTION
I guess I had a senior moment, or two, earlier today.
Sorry Gene, but in reviewing my notes, the total material cost is about $800.00, not $600.00, as I stated in my previous post.
My apology.
Time for another vacation.
Old 02-25-2009, 04:19 PM   #12
LLB21's Avatar
How sad. It always hurts to get that first ding.
I would guess about a $3000.00 job give or take a little. My local dealer has a manual from Airstream that gives 24 hours to replace the lower sheet.
Louie
LLB21 is offline   Reply With Quote
Old 02-25-2009, 04:23 PM   #13
To my knowledge, Airstream does not have a "crash book."
But, I will check and find out next week, when they are open again.
The only book available, that I am aware of, I wrote back in 1970, for Caravanner Insurance, the old insurance division of Airstream.
Old 02-25-2009, 07:54 PM   #14
Master of Universe
Gene's Avatar
Andy, thanks for the correction.
LLB, do you know how old that manual is? There are books for autos and trucks, but I would guess there are too few Airstreams for someone to publish one. Of course, dealers who do a lot of body work could compile their own manuals from experience and even exchange them. I think an experienced dealer would get work done a lot faster.
Gene
How much do you think it would cost to repair bellypan? bnhilfiger 1965 Safari 5 03-20-2008 07:44 PM
cost njoysrvin Full-Timing 12 03-04-2007 02:34 PM
What Will It Cost You? GT1963 WBCCI Forum 1 01-27-2006 04:20 PM
