Originally Posted by RichHog
So I have a dent in similar spot a little higher and to the right. We pulled it out some but there is a crinkle. Because it involves a bit of the window rivets it’s labor intensive and will require one panel ($700) replaced. With labor I’m lookin at a 4,000 repair. The shop will make it look new again and they do great work. Here’s the bad side if you don’t fix it right it WILL be a price/value deduction if you don’t fix or do a patch job. Worse though every time you pull into a rally or hang with other Airstreamers you will get heckled and asked about how it happened and why you didn’t listen to your wife, etc. Just saying.....
You can get to it from inside, but it will take a bit of work to get interior wall materials out of the way. Get a short length of 2” x 2” pine, round it on one end and work it to spread the dent outward. Possibly could have a slight crease mark, but won’t be as obvious as your original dent. Anyone who says it can’t be done, hasn’t tried. I’ve removed two dents by pulling interior wall from behind rear bed head board. Okay, I backed the Fiamma bike rack into a pickup truck.
