Old 07-16-2010, 01:10 PM   #1
denver , Colorado
cost of adding AC and Pex plumbing
hello
i am considering the purchase of a 67 GT. mostly reconditioned and in very good shape overall. I would like to see if anyone can shed some light on approximate cost to install an AC unit and redo the plumbing with PEX. thanks.
fiji69 is offline   Reply With Quote
Old 07-16-2010, 01:12 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Originally Posted by fiji69 View Post
hello
The cost depends on whether or not you plan on doing the work yourself or having it done by someone else. What are your plans?
Bill
Just my personal opinion
Old 07-16-2010, 01:20 PM   #3
denver , Colorado
reply
definitely having it done by someone with experience. there are a couple of local AS dealers in Colorado that the work could be done by. thanks for the clarifying question.
Old 07-16-2010, 03:02 PM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I'd say about $800 for the Air Conditioner, and for a GT, about $400 for the pex plumbing.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-16-2010, 03:52 PM   #5
denver , Colorado
reply
the dealership in CO that i called quoted me $1800 for the AC and $3000 for the plumbing?
Old 07-16-2010, 04:37 PM   #6
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
YIKES!!!! That's outrageous. You need to call around.
You did tell them the PEX was for a tiny GlobeTrotter, correct? A new A/C costs about $600 and should only take an hour or two to install. Maybe they charge you for several coffee breaks??
BTW, PEX is so easy, anyone can learn how to do it. As for the A/C, best to have the pros do it who have the lift to mount the A/C on the roof.
1958 Overlander
4CU 1st VP
Old 07-16-2010, 06:50 PM   #7
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Depends if it has an ac on it now or not,if not they must cut the hole & reinforce,run 20 amp circuit.
so the ac price is a lot closer than the pex, now $3,000 for the pex I think I could drive there and still make money @$3,000.That is a total rip off. Dave R&R Plumbing
easyride is offline   Reply With Quote
Old 07-16-2010, 07:37 PM   #8
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
That's true. I assumed there was already an old A/C mounted.
1958 Overlander
4CU 1st VP
Old 07-16-2010, 08:25 PM   #9
1977 31' Excella 500
plano , Texas
Even if there was an old AC unit, it would have been one of the 2 copper lines feeding through not the standard 14x14 hole. This would require a significant amount of time to adapt. Now for the PEX, when I redid a 67 sovereign, the parts alone were over $100 (you don't know how many adapters/elbows/etc you need until you realize how much they cost each... sorta like door knobs in your house). Also you end up removing most of the trailer contents to do it right.
With that being said, I would expect the AC to be closer to 1500 and the plumbing closer to 1000.
-t
tschat is offline   Reply With Quote
Old 07-16-2010, 08:47 PM   #10
These are two common DIY projects on vintage Airstreams. Are you handy at all?
I replaced my A/C for the cost of my A/C, around $750 shipped for a 15,000 BTU Carrier AirV low-profile and that includes the heat strips.
I replaced all of my plumbing with PEX for around $150 including tubing and all fittings.
These are not terribly difficult projects for even a beginner DIYer.
Good luck!
Old 05-19-2017, 05:15 PM   #11
Fort Lauderdale , Florida
My 1970 23' Safari does not have an A/C system. How much would it cost to get a rooftop A/C system installed, and how would one hide wire and drain pipe? I am in Florida. Does anyone have any recommendations on companies or contractors that can do the job?
writemate is offline   Reply With Quote
Old 05-19-2017, 06:55 PM   #12
1986 31' Sovereign
Miami , Florida
JD Sanders in Alachua is a family-owned, honest outfit with lots of Airstream experience. You might want to give them a call.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 05-19-2017, 07:13 PM   #13
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Being a plumbing contractor in one of the highest priced markets in the country(montecito) and being able to charge a premium for my service I find the $3k pex repipe way out of line, if there is not a lot of cabnetry and such to disassemble to gain access to the piping then $1k leaves room for a decent profit. I hate to see gouging and this is a prime case. Unless they have to disassemble the trailer to get the pipe runs in.
I vote do it yourself, google, youtube and home depot are your freinds.
Basically 4 fixtures to plumb to with a w/h and your city and tank piping.
AlinCal is offline   Reply With Quote
Old 05-19-2017, 07:20 PM   #14
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
If you're buying a '67 trailer and even if it appears to be in good shape, I think that the reality will be that it will need a significant amount of ongoing maintenance. I've owned three used travel trailers (2 have been Airstreams) and all appeared to be in good condition when I bought them. However, all of them have required more repair and maintenance that I could have imagined in the beginning. This is likely to be the same experience that you may have, too. So you might want to re-evaluate how willing you might be to tackle some of the restoration that will inevitably be required.
Back to your original question...I think that the price quote that you received is likely reasonable for the AC. However, the PEX plumbing is probably about twice too much, unless fixtures, etc. need to be replaced. I reworked my plumbing with PEX, and it was a lot more work than I thought it would be.
All my best,
Steve
Steve
Steve Bryant is offline   Reply With Quote
Cost of new AS cdlusmc Trailer Values 22 04-21-2010 06:43 AM
What's a '71 cost new? Lumatic 1970-79 Tradewind 11 08-02-2008 10:56 AM
What Will It Cost You? GT1963 WBCCI Forum 1 01-27-2006 04:20 PM
What did it cost new? Stefrobrts Trailer Values 6 06-14-2004 01:34 PM
