Old 03-12-2013, 02:31 PM   #1
2012 23' FB International
Hollister , California
Corrosion
Hi all. Have a 25ft International. Bought new in Ca. 8/11. Noticed a small bit of corrosion where the side running lights (turn signals) steel or pot metal base plate meets the aluminum skin. In the last month or so the area of what appears to be aluminum oxide is more pronounced. Is this galvanic corrosion? It would seem prudent for the manufacturer to have separated the tear drop shaped light base from the aluminum by a rubber gasket. Anyone have the same problem, and if so, what did you do about it? How does one remove the running light from the trailer? I see no screws. I'm sure that removing the plastic lenses would allow dissasembly but how do you get the lens out? your help would be appreciated
Luftnoggin is offline   Reply With Quote
Old 03-12-2013, 02:44 PM   #2
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
Here is some reading material for you!
Sorry....
Bruce
http://www.airforums.com/forums/f142...ams-31743.html
Bruce B is offline   Reply With Quote
Old 03-12-2013, 03:11 PM   #3
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Luftnoggin, if you don't want to go through fifty some pages of what's called a filiform education, call Airstream tech, and ask them for samples of what they use to combat this dread disease. I think they will send you some samples.
It's actually a chemical reaction between the elements (depending upon where you live) and the aluminum that's been cut and is exposed to those elements out of doors.
It's a PITA and Airstream will not treat it under their warranty. All you can do is recognize it, and treat it accordingly.
We all run into it sooner or later.
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
