Old 07-18-2015, 08:17 PM   #1
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Cooktop eye will not light with ignitor
I tried the cooktop for the first time today.
Left rear eye lights fine.
Right rear eye lights fine.
Front center eye will not light with ignitor.
Why have I never tried before?
Why didn't I try back in October 2012 at the dealer on the day of purchase?
Why didn't I try before the warranty ran out or while I was at Jackson Center getting other work done?
Why won't the one eye light with the ignitor? It lights if I turn on the gas and hold a match to it.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-18-2015, 08:25 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Dirty?
MICHAEL
Old 07-18-2015, 08:51 PM   #3
m.hony's Avatar
2013 30' Classic
Somewhat new still in excellent condition trailer-
Dirty where?
Stove has never been used.
How would it get dirty?
TAC #MS-10
Airforums #70955
Old 07-18-2015, 10:35 PM   #4
2002 19' Bambi
Lafayette , California
As mentioned in another thread (http://www.airforums.com/forums/f426...er-135685.html), it is very possible that the ignitor wire on the burner that is not lighting has come loose. Figure out how to lift the stovetop (varies with the stove model) and check on the wire.
Tim
Tim A. is offline   Reply With Quote
Old 07-18-2015, 10:44 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Are you getting "gas" at that location?
The "orifice" can be blocked with manufacturing trash. Or a bug of some kind.
Just to be clear.... Are you talking about the "burner" eye? The place where all the fire comes out of? When you turn on the gas, can you "hear" It flowing? When you turn the "igniter" Do you see a spark?
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-19-2015, 05:25 AM   #6
m.hony's Avatar
2013 30' Classic
Yes. The burner lights with a match.
It just won't light with the ignitor.
I thought I said all that in the first post.
The back 2 burners light with the ignitor. The front burner will not light with the burner.
Maybe the term "eye" for burner was confusing? Maybe we only say that in the south?
I was just trying it because I never had in 2 years and 9 months of having the trailer.
I just got to thinking, although we don't like the idea of cooking in the trailer (odors, stains, grease, etc.), we might at least boil water or cook something on the stove instead of a Crock Pot. Then my next thoughts were "Does it work?" and "How do I light it", thus my discovery on a random hot July Saturday night at a campground in central Mississippi.
Just like I occasionally light the gas space heater at home just to see if it works. We have never used it in 9 years and 4 months of living there, but it is good to know it works if we ever have a power outage in the winter- i. e. an ice storm-
TAC #MS-10
Airforums #70955
Old 07-19-2015, 05:37 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I have seen this on brand new trailers. Either the connection has come loose from the burner or ignitor, or the connection has some corrosion on it, preventing it from working. When you spin the ignitor, do you see a spark on the edge of the burner that won't light?
Most of the newer stoves have burners you can remove without having to remove the stovetop. Simply remove the grate over the center burner, and twist it about an eighth of a turn counterclockwise, and gently lift it off. You should see the wire coming from the electrode on the burner. Unplug it, and plug it back in, then replace the burner. Try lighting it.
Old 07-19-2015, 07:43 AM   #8
richinny's Avatar
2011 34' Classic
does anyone know if there are air gap specifications on the air gap for the spark. i have to vary the gas on my front burner and set it near the low setting to get it to light.
Ricky
Old 07-19-2015, 10:59 AM   #9
2012 25' FB Flying Cloud
Georgetown , Texas
Sometimes one of our burners won't light with the igniter if it is slightly off-center. You could try re-seating that burner. I'm not at the trailer, but as I recall, they sort of sit flush with the top and then turn slightly to lock in place.
We've had burners that would light before, and then won't after we've towed the trailer; re-seating the ones that won't light has fixed the problem for us.
barrettjl is offline   Reply With Quote
Old 07-19-2015, 11:21 AM   #10
Nomad518's Avatar
2001 25' Safari
Vancouver , Washington
As Tim said, lift the top of the stove and check the wire leading to that igniter. I had the same problem on one of our burners and the wire was disconnected. Probably happened as I was towing the trailer down a bumpy road. My stove top is hinged at the back. Just grab it in front and lift. It was a two minute fix that required no tools, just good eyesight to see the wire that had become unplugged.
Nomad518 is offline   Reply With Quote
Old 07-19-2015, 02:20 PM   #11
amaier7771's Avatar
2013 25' FB Flying Cloud
Colorado Springs , Colorado
My right rear burner also would not light with the igniter, (after a long ride on a bumpy road!!!), but would work fine when lit with a match. Using a plastic-putty knife on the front left and right corners of the cook top, it popped up easily, the igniter wire had become disconnected, I just pushed it on, and now all works fine. A 2 minute fix. Hopefully, this will fix you situation also.
AL
amaier7771 is offline   Reply With Quote
Old 07-19-2015, 02:35 PM   #12
m.hony's Avatar
2013 30' Classic
All of those are good, reasonable suggestions. We are back at the house and it is just too hot to ho to the trailer and check it out.
I'll try some of these suggestions next time out- maybe August 14 if not before. Next weekend we are staying home.
TAC #MS-10
Airforums #70955
Old 07-19-2015, 02:35 PM   #13
m.hony's Avatar
2013 30' Classic
That sentence made no sense-
It is too hot to go into the trailer-
TAC #MS-10
Airforums #70955
Old 07-19-2015, 03:19 PM   #14
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I have been fighting with mine for a while, top off, burners removed.
I tried twisting the burners to get a better ground for the spark, this fix worked intermittently, then failed. I tried to route the ignition wires to keep from grounding along its length.
What I found is the insulation on these wires to be extremely thin to the point of grounding out. Grounding out is where the electricity leaks out from the insulation and grounds out on the metal surface it's lying on before it gets to the sparking terminals on the burner head. Best way to see this is top cover off, at night and look for the blue spark anywhere along the wire.
My final fix, is still called a "fix" in that it still works after three months. Cover each wire individually with better insulation from the igniter knob to the burner head. I used some clear tubing that I had left over, specifically, air hose for fish tanks. I tried to bundle the wires, and use less tubing but I found it still was grounding out between the wires. So back for more tubing at a pet store, 25' @ $7.00 enough to do maybe three cook tops.
"Chip Tank" is in Flagstaff Az.
CDONA is offline   Reply With Quote
Replacing the ignitor on a Dometic RM100 wacnstac Refrigerators 2 03-29-2009 08:55 PM
water heater ignitor ground john hd Water Heaters, Filters & Pumps 14 08-26-2006 08:58 PM
Main Propane Ignitor "Element" Cat Furnaces, Heaters, Fireplaces & Air Conditioning 11 05-23-2005 04:28 AM
ignitor points trumpwer LP Gas, Piping, Tanks & Regulators 2 05-02-2005 01:44 PM
65 Dometic Refrigerator, ignitor ChromeHome Refrigerators 10 04-24-2005 04:15 AM
